Although regular rugs and carpets seem to work, is there a better acoustic material to manage peaks and dips? Why don't people just lay absorption panels on the parts of the floor where one wouldn't walk?
Indeed. The reason he does that is because the timbre change seems to come at 500 Hz+ so even a thin absorber works.F. Toole reccomeds a high-quality clipped-pile woven carpets (with porous backing because the sound must be allowed to penetrate into the felt underlay) on a good carpet underlay— 40 oz/sq yd (1.4 kg/m2) hair felt, which is typically about 0.43 in. (11 mm) thick. We should avoid rubber or plastic backed carpets. Sound Reproduction page 478.
The reason the floor is different is because the reflections there are heard equally the same by both ears (assuming on axis). The psychoacoustics of that is different than the side walls where one ear will hear the sound differently both in time and tone.
On the walls, you want broadband absorption which should go to 200 to 300 Hz (transition frequencies). That requires at least 4 inches absorber. So the rug there doesn't work as well.
why, theoretically, we need to treat the floor differently than the walls?
I use an OEM of my acoustician called Noiseout which sits above the subfloor and under the carpet pad
http://noiseout.com/
It converts the floor to a bass trap
you don't even know it's there
think concert hall.
diffusive walls and ceiling, wood over solid flooring under the sound source, absorbtive listening area.
you want to retain maximum musical energy and then allow it to propigate naturally. once energy is absorbed (near the sound source) there is a tonal shift and you can never recover that energy.
so hardwood floors under the speaker 1/3rd (2/5th) of the length of the room, carpet under the listener 2/3rds (3/5th) of the room.
my room is constructed exactly this way for these reasons.
the wood flooring of choice depends on what is underneath, and if it's concrete, how much hydrostatic pressure is in the ground....and how effective the vapor barrier might be. there are wood products for any application.
and btw, moving speakers around on a hardwood floor with the wood running perpendicular to the length makes life very easy. i can do 1/8th" adjustments easily by myself with 750 pound towers.
For a concrete slab to be impacted by hydrostatic pressure, it must be below the water table on the site or intrude into a natural water pathway.
according to my contractor (I'm no expert in any way), a measurement was done to the ground under my room prior to the concrete pour for my room, and it was determined that the moisture content and hydrostatic pressure (the term he used) was such that I could use glue down wood flooring to the concrete since I was also using HVAC and my room would have a constant controlled temperature range. also, to your point, the grade was above the water table and not on fill (the term used was that I'm on glacial till).....and no springs or other factors.
the measurement was done at multiple times in the winter and early spring time, maximum moisture times here in the mountains of Western Washington state. some types of soil have higher moisture content than other types.
my issue was that I wanted a wood floor (over concrete) under my speakers, but mostly wood floor requires some sort of air gap when installed over concrete to allow for expansion and contraction as the temperature and moisture changes in the ground. since my acoustic designer spec'd wood, and I anticipated having quite heavy speakers (my current speakers are -4- 700+ pound towers) and I did not want the floor to flex and have to fight that issue.
