It is always fun to research even small elements of one's future stereo system. I found today a fabricator of what I think are beautiful and functional walnut cable lifters.
Mike Goppert, proprietor of TimbreDynamics, makes cable lifters. He will customize to satisfy specific requests.
They are quite heavy, and will not be tipped over even by heavy cables. Mike can substitute the standard felt on the bottom with Sorbothane.
![5C865F37-7628-47A5-9B69-2468CBD616B7.jpeg 5C865F37-7628-47A5-9B69-2468CBD616B7.jpeg](https://www.whatsbestforum.com/data/attachments/64/64524-751677d5d6d2f68ce486d82528232bff.jpg)
![3C72C6B2-047D-4FD0-A688-02F7935B5A25.jpeg 3C72C6B2-047D-4FD0-A688-02F7935B5A25.jpeg](https://www.whatsbestforum.com/data/attachments/64/64525-fe207b97b0bbea4d1f1d24e6668bf150.jpg)
From Mike's Etsy page:
Materials:
American Walnut, Urethane, Black Marble, Felt, Chrome metal
Description:
An attractive and highly functional audio cable management system made from the finest materials. The cable platform is made from 1.5'' (38mm) high-quality handcrafted American walnut butcher block hardwood. Includes a 1.5'' (38mm) tall marble base which makes for a solid heavy-duty platform on any surface. Designed to hold both ribbon and round cable. The circular opening can carry up to 1.25'' (32mm) round cable and is large enough to thread any standard size XLR/Neutrix connector. This will make a beautiful way to finish out any high-end system.
Standard Features:
Solid hardwood butcher block cable management
Heavy-duty black marble base with soft felt base padding
Ribbon and Round cable management
- Ribbon cable slot width: .25'' (6.4mm)
- Circular hole diameter: 1.33'' (34mm)
Options:
Choice of Wood Finish (Natural or Dark Walnut)
www.timbredynamics.com
Materials:
Description:
Standard Features:
Options:
![www.timbredynamics.com](https://static.wixstatic.com/media/35c83f_e2dad1da366645feab278998c5ca07e5%7Emv2_d_8268_5847_s_4_2.png/v1/fit/w_2500,h_1330,al_c/35c83f_e2dad1da366645feab278998c5ca07e5%7Emv2_d_8268_5847_s_4_2.png)
World-class Home Audio | Timbre Dynamics
Timbre Dynamics designs and builds custom high-end home audio components made with best-in-class materials with real attention to detail.
![www.timbredynamics.com](https://static.wixstatic.com/media/35c83f_e00d39096cd3413fb56c772c50542467%7Emv2.png/v1/fill/w_32%2Ch_32%2Clg_1%2Cusm_0.66_1.00_0.01/35c83f_e00d39096cd3413fb56c772c50542467%7Emv2.png)
