110V to 220V transformer
JGlacken
64
21
913
Hi All,
I am able to buy a 220V amp that I want. The seller cannot convert it to 110V. Is there a unit that you all would recommend to convert 110V to 220V
that would be clean power? I guess I could have a 220 line run, but not sure if I have any room in my boxes.
Thank you in advance,
Jeff
Al M.
8,796
4,550
1,213
Greater Boston
Knowing how much power it requires may help.
I had a step-up transformer for my previous monoblock amps, about 300 W power consumption each (600 W total; output only 15 W/ch -- push-pull triode class A). I used a standard 3000 W step-up transformer ($ 147 back in 1997), but the power also went through a Tice Powerblock II conditioner at the backend. The amps sounded very dynamic, but perhaps I should have over-dimensioned the step-up transformer even more (10 x rather than 5 x amp power rating).
Hi All,
Jeff
Sometimes it is very simple to convert 110 to 220. In my amps voltage determination is predicated on the fuse positions in the chassis. My amp can easily be changed from one to the other by moving the fuses inside the amp
Elberoth
2,011
259
1,170
Poland
What amp is that ?
What amp is that ?
Lamm is a matter of changing the fuse positions to change voltage. Only problem with my ML3 is that Vlad insists on being the one to move the fuses which is OK as the amp has to be turned over and the bottom opened to access the fuse panel
RogerD
3,734
319
565
BiggestLittleCity
My VAC's have that feature. I installed 220 downstairs just in case I decided to switch over to 220. I checked the line is 240v and the VAC’s are setup for that voltage.
16,213
13,679
2,665
I vote for running a 240VAC line.
JGlacken
64
21
913
Thank you to all.
