Audio Research Reference 160M
16,185
13,610
2,665
marty
4,196
2,520
United States
Well, well, well...
After years of denigrating everyone who uses output tube autobias by saying it simply can't be done without compromising audio quality, they have apparently changed their tune and have implemented this feature now (and probably forever). Better late to the party than not at all. Now, we'll just have to see if their reliability factor has improved from past performance (I blew up both of my 610s within a week of installing them many years ago). I certainly hope so.
Reactions: RussR
16,185
13,610
2,665
The most interesting thing to me is that after VTL offered tetrode/triode switching at least 20 years ago, ARC is now incorporating that flexibility into this amplifier and, presumably, future amplifiers which will inherit the 160M’s design characteristics.
When in the future ARC upgrades the 750SE to the circuit design of the new 160M with triode mode, then it would be fascinating to perform a direct, apples-to-apples shoot-out of that future ARC versus the Siegfried IIs.
Reactions: shakti
marty
4,196
2,520
United States
+1 But as far as the apples to apples comparison, I'll leave that to you Ron. I owned Siegfried's (and still own the 7.5 III pre which I consider a masterpiece). But as good as the Siggies are, my days of owning amps with a large number of output tubes are over. Even with auto-biasing and the superb logistics that VTL Siggies currently have for replacing a blown tube (and they do blow), a microphonic in just one tube can create headaches for weeks until you track it down. Been there, done that. Acceptable perhaps when you're younger, but it gets old quick (like we all do!)
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Well, well, well...
Marty,
I can't speak for sound quality, but reliability on the new (read: 2-3 years back) ARC series is impressive. We've had the line for about a year now, and we had *0* issues. Nothing. As you said, a few years ago, reliability was indeed a concern with ARC, and actually, when we were discussing the dealership opportunity with them, we brought this subject up as a serious concern we had. This was also addresses in the factory tour we did, and they showed the little things they've been doing to help with reliability.
I'm just glad their recent stuff is all rock solid, and, to my ears, are the best products they've ever done, across the board.
4,700
Marty,
Modern ARC is more reliable also because current tubes are much more reliable - even with very old series I only had problems when tubes broke. Dealers should persuade them to include a B+ fuse in supply of the high voltage. Did they add it in the new series?
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
I agree, the KT150 is an exceptional tube, much superior to the KT120s used recently, both in sound quality as well as reliability. The amps also go easy on the KT150s, given what other brands are doing with them.
I do not recall a fuse specifically in there, when they pointed out the protection circuitry in the new amps, but it might be there and I just don't remember right now...
DaveyF
6,129
181
458
La Jolla, Calif USA
+1
I would go as far as to say that if anyone is considering a new tube amp, then any amp that does NOT use a KT150 is going to be less on the radar. Having owned many tube amps in the past, my current pair with the KT150's are easily the most resolving of any I have heard. I am pretty sure that the KT150 is a big contributor to this attribute.
andromedaaudio
8,463
2,817
1,400
Amsterdam holland
Sorry my mistake its tung sol kt 120, very reliable ime.
IT might be arcs configuration they often use Just a few tubes for the wattage in comparison, IT might have something to do with it
16,185
13,610
2,665
Well, well, well...
One friend of mine own two pairs of Siegfried IIs and I believe he has had zero trouble with them.
Another friend of mine has been auditioning ARC Reference 750SEs and I believe he has had zero trouble with them.
Having written that I always tell people that I derive significant comfort from knowing that if a big VTL tube amp has a problem I can relatively easily (i.e., easy relative to fitting an amplifier into a wooden crate and arranging the pick-up, transport, delivery and return logisitics and cost) drive it up to Chino, CA to be looked at and fixed.
andromedaaudio
8,463
2,817
1,400
Amsterdam holland
Sorry for bringing cat up again .
Cat states in their manual that although bias changes over time gets lower , that is a good thing ,biasing older tubes up Will degrade the sound , they recommend to only adjust new tubes in the beginning and after never again
KeithR
5,156
2,819
1,898
Encino, CA
Well, well, well...
I wonder if their circuit is now similar to VAC which actually optimizes bias. They do mention a proprietary auto-bias, so doubt its like VTL or others.
By far the worst part of ARC amps of yore (besides the whitish/SS sound) was the manual biasing of tubes with a voltmeter. The 75, 250, and 750 can all be done via front panel for the past five years.
But yes, I agree on ultra-high powered tetrode tubes - I'd probably go SS with a tube preamp instead.
the sound of Tao
3,633
4,880
940
Single ended input with Triode mode option as well (at last)... very nice. Tho calling it Ref160 when it’s output has been reduced down from the Ref150 and GS150 to 140 watts is more of a marketing thing as a Ref140 isn’t going to sound as a step up from a Ref150. But i suppose if winding it back a bit makes it sound better or may increase tube life then that is a good thing. I also couldn’t see an output figure for the Triode mode but it hopefully might be at least 50 to 60 Watts.
For sure if it’s a sonic advance on the GS150 then it sounds a very promising option.
Comments on how successful the KT150 as a tube is proving also then makes me wonder how long before Cat also offer a KT150 version of their JL5. That would also be a nice thing to see. Maybe also with more and more KT150 amps coming out with time maybe the boutique tube makers like Psvane and Kron may also start offering their takes on the KT150 as well.
4,700
All recent ARC amps could be used in single ended mode. The manual states "approximately 75 watts/ch in triode mode " and also refers the longevity of KT150's - KT120's were supposed to be replaced at 2000 hours, KT150's at 3000 hours.
People will have to get a logbook - the signal tubes (6H30) should be replaced before 4000 hours and the KT150's at 3000 hours. I think everyone will replace them all at 3000 hours!
the sound of Tao
3,633
4,880
940
50 per cent more output tube life is very useful and 140 Watts linear and 75 Watts in triode would make them a nice option for quite a few speakers I’d imagine.
Very much looking forward to them being released and also wonder if there’ll be a Ref250 replacement with triode mode also somewhere on the horizon... hope so.
andromedaaudio
8,463
2,817
1,400
Amsterdam holland
A logbook hmm sounds to much like work.
Luckily i m deaf anyway , i cant differentiatie on cables CD player s , and tubelife. , Lol
Saves heaps of money
analog brother
233
3
i like these monoblocks. they look sexy.
and you can use your choice of kt-88/120/150.
some nice 88's will sound creamy.
Elliot G.
3,317
3,030
1,910
Fort Lauderdale, Florida
www.bendingwaveusa.com
Well, well, well...
I cant speak for reliability since they are new and I have not owned them but they did sound good at Axpona. It was one of the few rooms I had time to visit and liked what I heard. It seems to be priced at a good number as well.
Me personally I am done with things that glow in the dark I have seen the light LOL and will live with my M1
