Cable Lifts thread
Speedskater
941
15
368
Cleveland Ohio
So far I have found two possible reasons for cable lifters:
1] they might tidy up room appearance and make vacuuming easier.
2] they might prevent cable color agents from staining a light colored carpet.
Reactions: bazelio
thedudeabides
2,127
651
1,200
Alto, NM
Per a previous recommendation on this site, I use CD cases. Very audible, positive impact. Total cost about $5 for ten pieces.
Reactions: Scott Naylor
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
Empty CD cases, good idea. Very audible, positive impact?
_____
* Cable lifters can make vacuuming easier, like six inches from the floor?
Why not just disconnect them and move them aside for few minutes?
** I've never heard of speaker cables an AC power cables staining light colored carpets. It would have to be real hot and melt them, no?
BlueFox
1,709
406
405
Reactions: johndoe21ro
16,017
13,347
2,665
All kidding aside, these seem like a good idea by reducing vibrations in the cable. Maybe not for everyone, but for those looking for every possible tweak they might be useful.
https://shunyata.com/products/accessories/df-ss-cable-elevator/
Bud, these do look good and well-made! The rubber band bridge also makes some sense!
Who is going to do a comprehensive sound test of these Shinyata elevators versus the Furutech cable elevators?
NorthStar
24,305
1,323
435
the sound of Tao
3,620
4,838
940
+1 on the Shunyata lifters, I have the previous version and they do the job nicely. I also borrowed the furutech lifter a while back but that coincided with the start of my house renovation and then house sale so I didn’t get the chance to use it at the time so can’t say as to the performance differences. Impressive bit of kit though.
However, i wouldn’t imagine using the Furutech lifters for more than use at power cable ends and in reality am happy with using Shunyata lifters and then Entreq wraps around the connectors. This combination has a nice functional look overall, not too OTT in cost and a good balance of both dealing with shielding and mechanical support for power and signal cables and connections.
Speedskater
941
15
368
Cleveland Ohio
All kidding aside, these seem like a good idea by reducing vibrations in the cable. Maybe not for everyone, but for those looking for every possible tweak they might be useful......................
Not that it matters in the least, but the cables will vibrate more when suspended in the air like guitar stings than when laying on the carpet.
NorthStar
24,305
1,323
435
You?
You are the best audio reviewer/writer @ WBF.
16,017
13,347
2,665
You?
Thank you, but, no, I am not.
(And you don’t need to be brown-nosing like that.)
16,017
13,347
2,665
Thank you, Bob. :)
JackD201
1,425
1,820
Manila, Philippines
I use lifters for two reasons. First to keep dust bunnies at bay and second to make sure there is less stress on receptacles. Sonically whatever improvements there might be are in the "I could just be imagining it" category. I can't really say. I don't have wall to wall carpet so there are no benefits to be had on that front.
4,698
Ron,
As far as I could see the Furutech cable elevators are intended to be used with power cables and the Shunyata elevators with signal cables - they can not be compared.
Priaptor
929
19
FL
Ron,
I think as Elliot mentioned, Furutech has now has two sets of elevators, those intended for power cables and those intended for cable elevators.
As to the support for the power cable, my MSB Select II is almost unusable with the large Gobel fitting without the Furutech as the leverage without it causes it to unplug too often. I think these high end manufacturers of all brands would do well to build their products with better support for cables of all types knowing that all (or almost all) endusers will be using these type of high end power cords and cables.
4,698
Thanks - can you post a link to them? I was recently at our Furutech distributor presentation of the cable elevators and was only shown the NCF elevators for power cables.
Elliot G.
3,286
2,958
1,360
Fort Lauderdale, Florida
www.bendingwaveusa.com
thedudeabides
2,127
651
1,200
Alto, NM
Absolutely. Less noise, better imaging, less smearing, etc.
Problem is they are inexpensive so many folks on this site are (unfortunately) unlikely to try them. :cool:
And they do reduce any "floor vibration" to a single point of contact for each case used.
Highly recommended for raising cables off the carpet for those that don't want to spend thousands of dollars on the "high end" lifters.
