Clear audio Absolute phono
gian60
2,508
1,951
343
Someone listen this?
Could be sunday i will try at home,one friend want to change with something i have and don't use
Can be a second phono in my system,i will try
jfrech
2,157
753
1,160
Austin
I am curious too
gian60
2,508
1,951
343
So i listen it for 4 days and i can tell is very good
Is a phono in current with one input balanced and one not balance and output only balance,
My P1 is better in everything,but forgetting P1 i liked it because is very transparent,deep bass,and neutral and good scene.
Then everything you trial is connected to his cost
Was second hand around 5.000 euro and was a very good choice
Reactions: Stump
Down Under
195
46
333
Thanks for your reply.
Could you live with it if there was no P1?
