DB Protractor DBP-10
dminches
3,474
2,846
1,410
I have a question about the DBP-10. The instructions have you use the white card with the -15/15 degree scale and points A and B in conjunction with the clear card. However, the back of the white card also has points A and B with the grids.
Is the purpose of using the clear card and the scale to help one figure out how much to adjust the cartridge for each iteration? If so, do you get just as good an alignment using the back of the white card?
I guess I am wondering if I can just use the grids with points A and B.
rockitman
7,097
414
1,210
Northern NY
Just use the grid with point A and B. I don’t use that other card
Tango
4,938
6,269
950
Bangkok
Same here. Only use the one with null point A and B. Sound great as is.
Tang
jeff1225
3,013
3,265
1,410
51
I've found that you only have to use the clear card if you have a slotted headshell and a fixed tonearm mounting. With the SME sliding base, you just use the one card.
DDK is the expert on this device, I'm assuming that he trained his American Sound clients Christian and Tang to use the one card.
dminches
3,474
2,846
1,410
Even with a slotted head shell I don't see the need for the other card. The SME sliding base is the equivalent of a slotted head shell. The geometry should be the same.
ddk
6,261
4,043
995
Utah
The clear gauge is for measuring distortion, you can use it to check your setup with the SME or any other arm some of which don't give you any means for proper alignment or the it's geometry requires some compromise. For alignment setup you just need the white card with the graph and A & B null points.
david
dminches
3,474
2,846
1,410
Thanks David and everyone for your helpful comments.
4,700
IMHO the DBP-10 is meant to be used when you need to rotate the cartridge. What are the exact A and B distances from the center of the spindle? You should use it only if they are the same as in the SME protractor or want to use an alternative geometry.
Theoretically we could use only the A point to align a SME - if A is correct B should also be in the proper alignment. Older SME protractors had a single point. In a real world with small errors we can play to split errors between A and B! :)
dminches
3,474
2,846
1,410
I didn’t think that the DB protractor was only for SME arms.
4,700
But probably it was designed for a defined tonearm length according to a defined alignment. It seems to me the DB-10 is a tool designed to help the user, not a calibrator.
dminches
3,474
2,846
1,410
I am using it to align a cartridge on my vintage Denon DP-59L. I had been using the MFSL Geo disc. I think this should do a better job.
ddk
6,261
4,043
995
Utah
No, it's a Baerwald (what you want for the SME) protractor for any length arm of course you can use it for Stevenson or Loefgren too just add the null points on the graph with a marker. You have another gauge to help you setup tonearms that fall outside any of these standard parameters too. The DB-10 is just a better easier to use tool than many of the other protractors I used in the past.
david
miniguy
437
168
350
San Diego area
Not so. With a slotted headshell, any re-positioning of the cartridge results in a change in effective length and thus offset angle. Just moving the arm in a sliding base only changes overhang and P2S distance. Effective length remains the same.
dminches
3,474
2,846
1,410
Thanks for the clarification and correction.
4,700
david
Thanks - I knew that the 3012-R is Baerwald - but some other SME's have the Stevenson alignment. It was in this sense I was telling that, using the points supplied it was not a reference. In fact the Baerwald points are not independent of tonearm length - but the differences from a 9" to a 12" arm are negligible , just around .2mm.
But my main point, just aimed at users of SME 3012R, not people using other tonearms or wanting to use slotted headshells, was why getting all this DB-10 system if we will not need it for a SME 3012-R? Isn't the SME protractor more than enough?
ddk
6,261
4,043
995
Utah
The protractor is often missing and isn't as easy as the DB Systems one to read. It's about the quality of the tool :)!
Of course you can use it with many other tonearms too and has tools similar to the one you used to figure out if you have the correct overhang for your arm+cart combination.
david
4,700
15 pounds including shipping will bring us a band new one with the SME logo! And, in this subjective hobby, my myopic eyes prefer the SME sharp and clear regular lines to those of the DB-10 ... :)
ddk
6,261
4,043
995
Utah
Whatever floats your boat but don't knock it before you try :)!
david
