If “There Should Be Tubes Somewhere,” Then Where?
16,215
13,690
2,665
Numerous respected high-end audio industry professionals and audiophiles are of the view that there should be vacuum tubes somewhere in every audio system’s chain of electronics. In which part of the chain are tubes most appropriate?
Should you put some tubes in the phono stage at the front, or in the power amplifier stage in the back, on in the line stage preamplifier in the middle? What are the pros and cons of having tubes in each location?
For those of you who believe in having tubes somewhere in the picture which component have you decided should be a tube component?
16,215
13,690
2,665
Hahaha! :)
RogerD
3,734
319
565
BiggestLittleCity
The only tube based electronics in my system is my DAC. Could it be replaced by a SS unit with the same SQ? Two years ago I would have said probably not. Today I would say I don’t think it would matter. But that’s only in my system with my grounding scheme.
pweg
171
121
353
Australia
I’m with dskip.
But next time can we flip the question? If there has to be 1 solid state device where should that be? I’d be happy to have 100% tubes.
dan31
1,019
369
1,653
SF Bay
I will get crap for this but I would say the phonostage if you listen to vinyl lp. I know this is the most vulnerable position when it comes to noise, but it just sounds better.
I’m sure a tube line stage is likely the most popular. I still have a Nagra PL-L in my 2 channel home theater and it is great as they only tube component in that system.
JackD201
1,429
1,820
Manila, Philippines
linestage is my vote
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
1,617
1,487
553
IMO and in the context of ‘normal’ sensitivity speakers, I would try use valves in a source position (eg dac output / preamp stage) for voltage gain and solid state power amp for current delivery.
bonzo75
22,643
13,674
2,710
London
+1.
Power amps are the last place I would decide on, as these are very speaker dependent. Some will require tubes, some SS, some which can handle both it will depend on the amp model and the preference. Pre amp will be valve in most cases except where synergy with downstream SS amps demands a SS pre. I also don't have sufficient exposure to Koda.
While Lampi is my favorite dac my second is Neodio origine for digital, and that's SS, not valve. My favorite phonos are valve but I also like some SS and my ying and yang is best serviced at the phono stage level
kodomo
1,003
1,615
330
For me, definitely with the power amps and with s.e.t. topology. For source components and preamps I prefer s.s.
I also think they are much better mated with high efficiency systems that have stable impedance.
GMKF
432
86
135
Munich
My vote goes to first gainstage of a power amplifier.
Although I find tube phonostages with a direct mc-in very interesting.
christoph
4,679
4,072
825
Principality of Liechtenstein
I’m with dskip.
Same here.
My SS piece of gear is in the kitchen, it's a squeezebox Radio :rolleyes:
the sound of Tao
3,640
4,895
940
Another vote for going with tubes in a linestage... the context of small output here seems to play to traditional tube strengths while challenging their constraints less, though with single ended low watt triode amps this in some measure also then applies. Am tempted to say with horns just go tubes all the way!
XV-1
3,618
2,629
1,860
Sydney
Linestage would be my first choice if there were only one place in the system where the signal is seen by a tube as all sources go through the preamp
plus 1.
bonzo75
22,643
13,674
2,710
London
The FM 155 was better than AR ref 6 in an all tube system. Ultimately the owner (Tzbc) preferred the Ayon conquistador to both
bonzo75
22,643
13,674
2,710
London
The Soulution 720 pre was better than the Allnic L5000 in an all Allnic system with Avalon compass diamonds.
