Kubala Sosna Realization cables
ationg
119
30
158
Curious whether anyone has experience and feedback on this new model from KS? Very little information on the net.
Thanks.
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
We've only had a complete Realization system for a small time, as the interconnects were in short supply.
My impression is that it sounds like a more open (on both ends) Elation. It's not frequency response, it's more "air" up on the highs and a more heft on the bass. Same result both on the Wilson as well as the YGs.
Joe Kubala will be in the store February 10th demonstration his new lines, Realization among them.
Folks with Elation, even Emotion, should seriously consider taking advantage of Kubala's upgrade policy, and consider Realization!
cheers,
alex
Reactions: DDgtt
ationg
119
30
158
cheers,
alex
Alex, thanks for feedback. I use Elation myself and think it is a very good cable especially in the mids. In my set up, the highs and the bass fall short a little. The bass particularly is a bit loose compared to another cable brand I have on hand.. If the Realization can improve in these areas, it will be a winner.
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Do you mind sharing the details of your system?
The KS stuff is some of the most "universal" cables I know, but still it might behave differently on different systems...
cheers,
alex
ationg
119
30
158
My system is Vitus amplification driving Rockport speakers. cabling a mix of KS and Crystal cables.
Regards
LL21
14,423
2,517
1,448
Regards
very nice!
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Regards
Great stuff!
A very nice and warm system already, so I can see anything less than Elation sounding a little closed in on top. For sure the Realization series will open up the extremes. I'd start with power cords and speaker cables from that series, and keep ICs in Elation or even Crystal Cable.
16,188
13,615
2,665
Eeeeesh! Another well-regarded, top-of-the-line interconnect to consider?
Has anyone compared Realization interconnects to Cardas Clear Beyond interconnects?
Alex, how does the Realization sound different than the Sensation?
Than the Elation?
Than the Emotion?
(I give up — back to Radio Shack zip cord for me! :p)
VPN
365
176
318
Hello,
I upgraded my speaker cables and preamp power cable from KS Elation to KS Realization. The improvement has more substantial than I expected. Better highs with more air, better lows with more quality/better timbre, better soundstage. Highly recommended!
Cheers,
VPN
Reactions: DDgtt
supersax
8
I believe this is the info you are looking for:
Realization Prices - January 2018
RETAIL PRICES in US$
Prices Per PAIR for Analog IC/ Speaker Cables … Per EACH for Digital Cables and Power Cords
Price Format: $250/ 80 = $250 for first meter / $ 80 for each add’l meter ($40 for ½ meter)
Example: 1.5m Fascination Interconnect = $1000 + (350 x 0.5) = $1000 + $175 = $1,175
RCA or XLR AIC - 11000/2000
USB Cables - 3500/800
Speaker Cable SC1 - 11000/2000
- Int. Bi-Wire SC2 - 500
- Int. Tri-Wire - 600
- Speaker Jumpers - 500
Power Cord PC1 - 3000/600
- 20 amp IEC - 90
Retermination - 500
- Per Pair-End (2 term)
Warranty Transfer - 500
- Must have proper and current SN registration
pke10000
84
29
123
- 20 amp IEC - 90
Retermination - 500
WoW ! Thank you.
IC is almost 4-times of PC..... Is it real?
Is there something special at IC ?
ationg
119
30
158
Hello,
Cheers,
VPN
VPN, how would you compare the Realization to other brands you have had?
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Than the Elation?
Than the Emotion?
Ron,
Sorry I missed your post from a while ago!
We've just replaced a whole set of Cardas with KS Emotion. It retained Cardas' warmth, but was much faster and open overall. The system sounded too closed-in and muffled with the Cardas before.
Elation lacks the nice additive warmth of Emotion, but trades that for a touch more transparency in the mids. That was the previous flagship. Now, Realization is more open and transparent still than Elation, and is the current flagship.
Sensation is one of the newer series of cables, which includes Realization on top, and it's basically a (great) mix of Emotion's warmth and midrange bloom and Elation's speed and transparency.
We have the cables in the store, in case people want to compare.
cheers
Alex
supersax
8
WoW ! Thank you.
Actually since the interconnects and speaker cables are in pairs, they are only about twice as expensive as the power cords! I currently own two Realization PCs (for my amp and preamp) and easily bested the Elations. I do know that the interconnects were on backorder at least for a while. Going forward, I will upgrade based on the recommendation in Append #7 of this thread.
Dave
VPN
365
176
318
Hello Ationg,
I upgrated speaker cables and one power cable from KS Elation to KS Realization. So far I have not done any comparison of KS Realization with other brands.
I can tell you that the KS Elation power cable did not go well with my previous DAC, but I have not tested the Realization with my current DAC. I find that power cables are very device specific, you have to really try in your system, with the specific device you use.
Cheers,
VPN
aldenberry
6
Has anyone compared the KS line to Transparent, especially with Rockports? Is there a cheaper way to Nirvana?
Cheers,
DCM (Rockport lover)
pke10000
84
29
123
Cheers,
Both are good enough. When I bought Rockport Mira then Atria now, I had to choice a speaker cable.
The result was easy, transparent. Because rockport uses same.
Then I had compared transparent xl and kubala elation power cord, then selected xl.
And I compared aes ebu cable also, then selected tranparent again.
It seems that transparent family make some synergy.
aldenberry
6
Thanks! No surprise.
