Tonearm choice for Kuzma Stabi M and ZYX Universe II
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Hi,
Please, help me decide on a tonearm for this combination of the TT and the cartridge. I already have the ZYX Universe II and plan to get the TT hopefully soon. Initially, I decided on Graham Phantom III. But now I am torn between Graham and Kuzma 4P. Any suggestion or advice will be much appreciated.
And another thing is the tonearm length. I've pretty much decided on 12", but after reading the recent debate on tonearm length, I am also in doubt. Maybe a 9" version would be a better choice? It is much easier to find a 9" Graham tonearm, and it is less wait time than for the 12" version.
Thanks,
Aziz
bonzo75
22,627
13,652
2,710
London
Dctom, another Lampi 242 user has the kuzma xl4 with 4p, Lyra atlas, colibri, and shelter harmony. Ypsilon phono and Lyra SUT. Ask him how difficult it is for his analog to outshine the Lampi.
That said, my favorite kuzma demo came from the stabi M and the 9 inch 4p with proteus and airtight phono. I also like the zyx. It is one of my favorite carts. It seems to be friendly to various arms, I liked it on SME, fr64s, Ikeda 407. Number95 uses it with the Graham elite. But since you have the kuzma stabi M, try the 9 inch first since they come made for each other?
Which phono are you planning?
Tango
4,938
6,268
950
Bangkok
Thanks,
Aziz
Dear Sir,
Just get a 4pt any length and be done with. It is an excellent arm that looks good on your Stabi. Regarding the length, if it is the same brand and model of arm, the sonic difference is very likely slight. If you don’t have two same arms of different length on the same table at the same time with the same cart you are unlikely to recognize difference.
Kind regards,
Tang
kodomo
1,003
1,614
330
I have the Stabi M and the standart 4 point. I use the continuous single silver cabling without the box with eichmann plugs at the end. I am very happy with it, do not get caught up in the 9", 12", 14" arm length, they all have pros and cons.
However, about the cable options, may I suggest using a single cable. This makes a difference, lower capacitance to start with. I use passive pre and it makes an audible difference. The box is good to try different cables but, single cable is about half the capacitance of the box. The box means more connectors, more loss regardless of the quality of the connector. It will also mean, you will keep buying different phono cables rather than buying new records :)
bazelio
2,494
1,748
345
California
Graham Phantom on Stabi M is just wrong. Sorry.
Get a standard 4-point. The table was made for that arm, and it's a great arm. The 9-inch 4-point is a lesser arm, IMO - not just a shorter version of the standard 4-point. You could go with the 14" 4-point if you don't mind keeping the cover open while playing records. Either way, I love my Stabi M + 4-point. And I second the recommendation for the Transfiguration Proteus cart. I'm running a Proteus on mine as well, and it's a winning combo. Every Zyx cart I've heard has been too warm, but I guess that can be a matter of taste. I'd prefer to get the detail and dynamics of the Proteus, 4-point combo and dial in warmth to taste through the phono or amp - if that's your thing.
bonzo75
22,627
13,652
2,710
London
Good to know the 9 inch is a lesser arm. Did not know that.
bazelio
2,494
1,748
345
California
One thing the 9" has over the 11" and 14" is sapphire pivot cups.... I can say that strong rumors suggest these becoming available as upgrades for the 11" and 14" in the near future. :)
Tango
4,938
6,268
950
Bangkok
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Dear Sir,
Kind regards,
Tang
Dear Tang,
I always enjoy reading your posts. You have a great sense of humor, which is a must in our crazy hobby:)
While it seems that 4p is a natural choice for any Kuzma TT, will it be a good match for the ZYX cartridge? I know, Graham and ZYX is a good combination, but have not read anything about 4p and ZYX.
Regards,
Aziz
awsmone
1,616
514
435
Canberra Australia
It’s weird how they put the sapphire pivot cups in the lesser arm ;)
BruceD
1,514
587
540
Agree with all --The 4 Point is the one in this case-- a far better choice than the Graham.
BruceD
awsmone
1,616
514
435
Canberra Australia
Dear Tang,
Regards,
Aziz
I think you have to think about your priorities optimal arm synergy with table versus cartridge
I don’t think anyone can give you the correct answer to this, but putting together combos everyone knows works well makes sense
Perhaps consider changing arm and cartridge to optimally match with Kuzma M
bazelio
2,494
1,748
345
California
They'll change the sound of the arm. But will that change be to your liking or not is unknown. I'm going to try it on one of my two 4- points when the upgrade comes available.
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
BruceD
Bruce and others, can you elaborate? Other that both Stabi and 4p are manufactured by Kuzma, what is the rationale for your preference? Certainly Graham Phantom is not a lesser tonearm, than 4p.
rossb
68
40
148
I've owned both versions of the 4 Point and I agree. The 9 inch version sounds lightweight by comparison. The standard 4 Point is superior.
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Ok, you guys convinced me, I’ve decided to go for the standard 4Point. Franc advised me, that the following wiring options are available: standard is Crystal Cable silver, optional is Crystal Cable Mono X, Kondo or Cardas Clear. I am thinking of Kondo, but any advice / opinion would be much appreciated.
Also, he said, I can send my cartridge to him, and they will setup everything at the factory and will ship to me completely configured and ready to use table. Do you think I should do it?
Thanks,
Aziz
bazelio
2,494
1,748
345
California
Thanks,
Aziz
Yes, let Franc do it, IMO! He's awesome, and his customer service is second to none.
I can't say I've heard any other cables on my 4 points other than the silver. I'd ask Franc which is the least colored and most detailed and go with that. I suspect it's the standard silver, but I'm curious as to what he says. And I'd personally characterize the 4 point itself as slightly warm (which is why the silver probably works well). But this is going to be a personal decision and there's no right or wrong answer.
abeidrov
VIP Donor
Dec 17, 2015
702
341
443
Moscow
Thanks for the response. I did ask Franc about the cables. He said, it is a matter of taste, and he would rather not give any advice:)
I also told him, my system is very revealing, the room is not treated, and sometimes I wish the sound would be a tad warmer. In this case, he said, I should try Cardas.
I have my doubts about Cardas. Standard silver or Kondo would be a safe choice in my view. Crystal Cable Mono-X is the most expensive option, but I have not heard anything about this brand.
Tango
4,938
6,268
950
Bangkok
I would go with the Cardas too as your system is already very revealing as you said. My carbon fiber arm wand tends to have narrower tonal width comparing to stainless steel. The 4 pt is also carbon fiber like SAT I believe. The silver wire will not help the tonal width but the copper certainly wouldnt worsen. The copper wire that come with my SME arm doesnt give any less details and resolution than the silver wire. It doesnt attentuate certain frequencies either. Then again it is the subject that can not really be recommended as Mr.Kuzma said.
Kind regards,
Tang
