Cleaning all your jacks, your speaker wire terminals, your interconnect's ends, your banana plugs (or spade lugs), your AC power cords, your inside wall electric receptacles, your junction breaker box, and all that Jazz ... :b
Ayre Irrational but Efficacious CD for $20. No one seems to know why it works, but boy, does it work?
Do you guys know of any other high value / dollar tweaks?
trreating the room is the most important thing you can do. Too bad it isn't cheap.
$360 for the Cathedral Sound panels![]()
what frequency range are they tuned for ? I suppose that is a good inexpensive way to go but I'm not sure you will come close to a flat frequency response room with them. Something like real traps where they are frequency tuned for bass, first reflection mid/hi and all frequency traps behind the listener makes for an optimal sounding room. They are much more expensive, but you get what you pay for. I spent close to $5k to properly treat a 16 x 16 space.
Drink less. ...Not only it's cheap, but you save money too; for buying more good music. :b
...And of course, you hear with more clarity and better concentration.
Speaker positioning. An hour or three can do wonders for many systems.
