Please try again! I changed itPlease try again - that link doesn't work!
Remove the header from the address to this: https://www.whatsbestforum.com/threads/avantgarde-horn-speakers.13714/page-19#post-727640Please try again - that link doesn't work!
Thanks. A rather more ambitious modification than I've made to my AG speakers! Personally I avoid mods to kit from well respected brands that can't easily be restored to original. That way, the used value can likely be maximised. In 15 minutes, the mods I've made to my AGs can be reversed.Please try again! I changed it
We'll be fighting for it, unless we live on different sides of the Pond!Now, who's got a used Mezzo XD or Duo GT for me?
Hi, no, the new Mezzo is my entry in Avantgarde and horn loudspeakers. Interesting dilemma you have… my guess… the choice between superior integration of low / mid vs. more natural mid / high.I'm in a bit of a dilemma!
Mezzo XD or Duo GT... I can buy one of those.
Which one is better?
@nirodha , did you have G2 before G3?
I’ve never heard either Mezzo XD or Duo GT but from all the reading I’ve done on both since release I would say Duo GT.I'm in a bit of a dilemma!
Best is giving the Duo GT a good listen somewhere. I have heard them several times and never thought about integration once. However the Mezzo (g2?) is grander, bolder, more mature. So my advice: listen to the Duo GT and if you like what you hear, go for it. Good luckSo low mid integration with the Duo GT still not as good as Mezzo XD...(?)
Doesn’t make sense. Just save up and buy the trio direct.If you can someday upgrade the Mezzo XD to G3 with the manufacturer
Thats a way of looking at it, but I will likely never get the money together which the Mezzo G3 is costing.If you can someday upgrade the Mezzo XD to G3 with the manufacturer, I wonder whether you might take the Mezzo XD (already "some of the best sounding systems you have ever heard")...and then know you have an upgrade path long-term. And you might never feel the need to have it upgraded by the manufacturer.
My listening room can not accomodatie Trio. These are to big.Doesn’t make sense. Just save up and buy the trio direct.
Yeah, that's the thing. Once you hear what makes a Mezzo so special, you cannot unhear it anymore. Which doesn't mean the Duo GT is a bad speaker in this regard.Best is giving the Duo GT a good listen somewhere. I have heard them several times and never thought about integration once. However the Mezzo (g2?) is grander, bolder, more mature. So my advice: listen to the Duo GT and if you like what you hear, go for it. Good luck!
I don't find a lot of people having problems with XD technology, but a lot of reading of some people writing a lot of having problems with XDI’ve never heard either Mezzo XD or Duo GT but from all the reading I’ve done on both since release I would say Duo GT.
There’s a lot of info out there from users of XD models that struggle with the software and integration whether Duo or Mezzo. It always struck me as an unnecessary addition to their speakers.
The G3 are completely different speakers, just watch AG’s long video on what is new in the design.
So if ever I was to upgrade it would be G3 without hesitation and I’d never swap my old G1 for any XD model even if there was no upcharge.
I would very much doubt that if the iTron amp is used for the Duo GT.So low mid integration with the Duo GT still not as good as Mezzo XD...(?)
I'd agree with all you say, although I did swap my S1 Duos (circa 2006) for Duo XDs!I’ve never heard either Mezzo XD or Duo GT but from all the reading I’ve done on both since release I would say Duo GT.
Ha Ha! We know your opinions on the greatness of the Trio and the poorness of the other AG speakers, but I'd not switch to the Trio even if funds permitted.Doesn’t make sense. Just save up and buy the trio direct.
well then we will Ha Ha! at you foreverHa Ha! We know your opinions on the greatness of the Trio and the poorness of the other AG speakers, but I'd not switch to the Trio even if funds permitted.
