Funny that you posted this pic of the 6K6GT as I was just discussing this tube on another thread. Though the original discussion centered on an old quad of Sylvania 6Y6 tubes I had been running we got on the subject of the 6K6 which I have not tried.One of the best combos so far, the GEC 6V6G with another "holy grail" recti, the French Mazda/Belvu 5U4G:
... and just to see how it would perform in the Atlantic, another French tube combo: the Visseaux 6K6GT with the "compact bottle" 5Y3GB.
So coming back to give an update on the Arcturus 18 pentode, a 14V tube on a UX6 base. I noted during the first listen that the highs were a little different and at that point I couldn’t pin it down as being rolled off or just what I would call “flatter”.So far I’ve only listened to one release but the sound continues to open the more I play. The first thing that struck me was the power felt in the bass regions- so far a little stronger than most pentodes.
Highs aren’t exactly what I would call rolled off but are very even/level when compared to the midrange. So not overly sparkly but definitely present. These tubes have a very smooth sound, whether it’s refined or just relaxed time will tell.
You can run your balanced dac in SE by leaving the rear tube sockets empty as the front sockets represent the positive phase of the balanced L/R signal.I would love to confirm that I can run a balanced Atantic TRP single-ended with either only 2 "music" tubes
Thanks so much! That’s what I thought, but freaks me out to run tube equipment with any empty sockets.You can run your balanced dac in SE by leaving the rear tube sockets empty as the front sockets represent the positive phase of the balanced L/R signal.
I don’t think there would be any advantage to using unmatched or different tubes in the rear/negative phase sockets for the purposes of achieving an SE output as leaving them empty has no ill effect on the operation of the dac.
Put a poker chip over each unused socket.Thanks so much! That’s what I thought, but freaks me out to run tube equipment with any empty sockets.
Congratulations on your new dac! Not sure what you were using before but you should find the TRP to be a great addition to you system.I've never owned tubes before but my default preference is for toe-tapping and/or emotional presentation versus clinical, and holographic. But I'm open to trying anything that worked well.
What tubes are you currently using? Have you spent enough time listening to them to know what you don’t like or to suggest what is missing?
There are many amazing tubes out there that work with the TRP- some will require adapters and others just a lot of money! I don’t know if you’re running balanced or SE but my advice would be to start with some lesser expensive examples and focus on what traits they have to offer when used in your system. Then bounce those comments off those here in the group for a more focused response.
If you search backward in this thread you’re find a document I posted that sums all of the comments made in the thread up to the point I started posting here. It should speed things up for you regarding the tube combinations used in the past. It does not cover the use of triodes though- that came later.
If your stuck on the idea of starting with the F2a send a note to @budburma to see if he can help you out.
This is more or less the case (especially when comparisons are done with NOS tubes in mind), but you can "mold" the sound to some extent by tube rolling.I was able to find some feedback in this thread, suggesting more or less that the GG3 is better for classical music, while the TRP3 has a better 'boogie' factor.
A lot can depend on system synergy too...Several experienced tube rollers in this thread have gushed about the F2a + Telefunken RGN2004 combo with the Golden TRP,
