These are Amperex medical 12AX7 from the Electronics for Medicine. These were made in Holland.
Amperex Herleen factory, 1963 codes (if I decoded it correctly).
These are interesting - Telefunken label, marked "SELECTED TUBE". Red tip. Made by Mullard. So .... why would Telefunken need Mullard to make them a tightly balanced, low noise, selected tube? Surely, they could produce them.
Date codes are Mullard.
Mullard Blackburn August 1967. ECC83 3rd production change.
No Telefunken <>, but there is an E.
Here is a nice quad of GEC U52 or 5U4G rectifiers.
Hammersmith factory indicated by the Z code on the glass. VB is February, 1964 (if decoded correctly).
These are 1962 GE 6BL7 GTA. These tubes were used in televisions for the vertical deflection and oscillator. They are a dual triodes with black plates and great for audio circuits. My amps use these tubes.
I also have the older 6BL7 GT from RCA and Sylvania.
Here is a nice quad of CV717 or 5R4GY rectifiers.
KB = K is manufacturing spec K1001 or K1006, B is for qualification by a UK authority
FE = STC, Oldway which is Standard Telephones and Cables, Oldway, England
U = 1963, E = May, F = June
