Good morning WBF!​
My experience has been to keep the network on a separate phase, dedicated circuit, opposite the rest of the system. I've always done it like that. I know when I installed the Torus WM unit the folks at Torus liked that approach...
Thanks for the input John and Markus! I was worried about ground loops forming which I hear can result in insidious degradation when it comes in the digital domain. Though the digital hash/noise from the network gear might be worse.
Reactions: John T
I always put everything on the same phase. I have had massive ground loops when the preamp and amp were on opposite phases. However, no experience with network gear. Since it is all galvanically coupled, I would have the same concerns. Issues may not present as audible hum at the speakers.
My entire stereo rig along with network gear is run through one Shunyata Everest.
Sparkies always like evenly loaded transformers. Typically they are not audiophile types, although there are exceptions.
John T, are you adding dual mono wood boilers to feed those hungry dual mono Mephistos? What sounds better, oak or maple? Ash?
I could see how dividing the pre and amps could create serious issues. Network on the opposite phase is supposed to be quieter. Torus didn't want my network associated with the isolation transformer in anyway. Separated. I think they indicated it can introduce noise. It just so happened that's how I always have done it...
Two questions for @Christiaan Punter or @Taiko Audio:
1. With the DCD and Router/Switch not being galvanically isolated from the O/IO - how important is it that they closely share the same AC ground?
How many people have the DCD/Router/Switch on a separate circuit vs the same circuit as the O+I/O?
2. A Roon extension is available to allow volume control of my preamp from Roon (it connects to Home Assistant and triggers an IR blaster to send Vol up or Vol down signals), allowing me to control volume directly from Roon without switching apps or grabbing the remote.
Any known detrimental effects from running Roon extensions? The Home assistant instance does poll Roon for song/playback position and status on an ongoing basis, though probably no different than having another Roon client connected to the Olympus Roon instance...
As MarkusBarkus mentions, it's best to use the same phase. Further, to avoid ground loops, it's best to use the same AC ground. Generally speaking, I find that using the same single ground for the entire system yields the best coherence and focus. Conversely, when sourcing ground via different cables and from different spurs, this tends to have a blurring effect. This is not an issue for galvanically isolated devices like Routers, which are frequently located in other rooms and on different circuits. When you have multiple 100% identical spurs, the outcome can differ, and there are other exceptions, as no two situations are alike, so it may be worth experimenting.
Regarding Roon extensions, basically, the more Roon does, the more network traffic it generates, and the more audible its effect. Then again, with Olympus, the Router, Switch, and DCD, we have various measures in place to minimize Roon's influence.
In cases where I disabled Roon volume control for a DAC, this has often been audible, even at 100% volume. However, in such cases, it is hard to determine whether the impact is due to Roon traffic or processes within the DAC. A preamplifier could behave similarly or differently, but neither Emile nor I have a preamp that allows this, so we have no first-hand experience with it.
If or when you decide to test this, I would be interested to hear the results.
