Standalone Audio Room
Grateful
35
20
10
62
Texas
Hi,
I’m getting ready to design a custom home and want to build a separate structure for audio. I’m thinking something like 800 square feet with a 12’ ceiling. Is there a golden rule calculator, so I can nail the best dimensions?
About 20 years ago, I had Rives Audio design my current room. Who are the best audio room design firms today?
Much thanks!
Hi,
Much thanks!
reach out to Warp Audio Academy. He does incredible work. His Instagram - https://www.instagram.com/vespersmusic/
Also, ratio can be a Golden ratio, a Sepmeyer Ratio, a Louden Ratio or a Bolt Ratio
Golden - 1 : 1.6 : 2.6
Sepmeyer - 1 : 1.14 : 1.39
Louden - 1 : 1.4 : 1.9
Bolt - 1 : 1.26 : 1.59 and 1 : 1.50 : 2.50
But I'd say discuss with Vespers
I would recommend plugging room dimensions (for a rectanglar space) into this website: https://amcoustics.com/tools/amroc
You should look for well-spaced peaks for a given combination of length (x), width (y) and height (z).
I used this when deciding on room dimensions for my own dedicated listening room (650 cm x 480 cm x 300 cm). My listening position is at one third of the room length from the back wall. My speaker plane is one third of the room length from the front wall. Loudspeaker centres are one quarter of the room width from each side wall. This creates a near field listening triangle that is approximately 2.56 meters from ear to tweeter with tweeters approximately 2.4 meters centre to centre.
Reactions: jadedavid
