The 12 Most Significant Preamps of all Time
Gregadd
1,812
1,850
Metro DC
1. Audio Research corporation sp3 1972 $650
2. Marantz model 7 1958 $254
3. Dynaco pAS-3 1960 $60(kit) $80 (assembled)
4. MarkLlevinson lpn/jc-2 1973 $1100
5. Vendetta Research scp-2 1988 $1895
6. Conrad Johnson art/gat 1996 $14,995/$20,000
7. Harmon kardon citation 1 $139 (kit) $239(wired)
8. Audible illusions modulus 3a 1996 $1895
9. Quad 33 1967 $120
10. Conrad-Johnson premier 3 1983 $2850
11. Mark levinson no.32 reference 1999 $14,950
12. Audio Research sp-10/sp11 1982/1984 $2995/$14995
The Vendetta was a phono stage.
http://www.stereophile.com/phonopreamps/640/
I wasn't an ARC SP11 fan. Step backwards IMHO. Start of their lean, hyper definition period.
If you don't mind me asking, where did this list come from?
Tom
Correct. I started to point out it was most often sold (or demoed) with an ARC Line stage. Also notable was the name Vendetta. JC thought he had been used and others took credit for his work.
Tom
Sorry Tom. My computer must have dropped it. the absolute sound issue 223 may/june 2012 pg.39.
Ahhh, thank you Sir.
Tom
I guess dealing with any modern codec (DTS-MA/Dolby TrueHD,FLAC, etc.) or being able to handle more than 2 channels or being able to do Room Correction or ...
None of that must be 'significant'. Right ;)
That's not a list from 2012, more like from 1980. I guess this explains why I do not subscribe to the AS
That's not quite the story as I know it :) But in part, what you said is true. And not only used but John wasn't paid for his work.
Or maybe it was limited to two channel?
I had the pleasure of using a No.32 at a show many years ago. From an ergonomics standpoint, I think it sets a standard matched by very few to this day.
Don't think it had that Levinson "sound?" It was way too dark and overly smooth for me :)
Jon- I think the context was 'historically' significant. If you assembled a list of historically significant automobiles, you'd have to include some real antiques, things that would be daunting to drive today, no brakes, center accelerator, carbs that go out of tune, and I won't mention Lucas electrics.
As to that list, I bought an ARC SP 3-a-1 back in the day when it was still current, circa 1974? At the time, I had access to a fair amount of new and used equipment, since I had dropped out of college and was selling hi-fi at a place that moved a ton of gear, good, bad and indifferent. It was not, at the time, an ARC dealer, although it later got the franchise. Anyway, a bunch of us took a few of the better preamps we had access to over to the 'other dealer' in town who was an ARC dealer.
The SP-3 was at an entirely different level than any of them- i know that sounds trite- but it was far more open sounding and musical than the range of solid state gear we had access to at the time.
I wound up buying one, even though I didn't get any sort of 'accomodation' and kept it for years, retubing along the way. It was eventually replaced by the SP-10 mkii, another ARC classic. By today's standards, I suspect the SP 3 would sound very old school tubey. The SP-10 probably less so, but keeping that sucker in low noise tubes was a full time job.
I agree. I had the 380s and found that it had more life. The underbelly IEC was a hassle though. SAme with my 360s, I misplaced the power cord when moving house and had no clue what to do. I found it eventually. Grrrrr.
With regards to the 32, I did say "from an ergonomic standpoint" and I still think that holds.
That IEC under the middle of the unit was a pure and unadulterated nightmare. I had almost forgotten about it. You had to put the unit on some sort of feet to be able to use that cord too!
But TAS is a basically a two channel mag. TPV deals/dealt with MC.
I think they call that a signal processor not a preamp.
I think the TAS list is too American. It should have included:
Burmester 808
FM Acoustics 268
Kondo M10
CAT Ultimate
All of these have been around for decades and today still are among the best.
I also think a Lyra Connoisseur should be on that list.
Thanks,
Roysen
