Mytek with Foobar, installation overview....
My current system is a laptop running FooBar ->> M2 Tech USB to PDIF ->> Benchmark DAC. This weekend I'll be replacing the Benchmark with the newly-arrived Mytek 192 DSD. If anyone can clear up a few points I'd appreciate it...
I already have WASAPI/ASIO drivers installed, but these should be replaced with latest for the Mytek, correct?
The 192 DSD-DAC manual describes two installation schemes, installation with DoP DSD or installation with native DSD. The DoP is recommended, but is this what I really need for my setup (DSD will be downloaded files)? Google couldn't answer the Dop part.
When all is said and done, can I expect seamless transition between playing hi-rez files and DSD? I am hoping that both Foobar and the Mytek will recognize and decode the different file types without any interaction on my part.
Thanks-
Tom
Thanks-
Tom
