Hello everybody! I would like to know if you recommend using a record clamp and what clamp or clamps you are using and what sonic benefits you are getting from them.
Most clamps do more damage like sucking the life out of the music. Best sounding so far is a clamp made by Stillpoints.
3. By far the best IMO were (are?) the vacuum clamping systems integral to some TT's. These applied equal pressure all across the disc (little holes in the platter) to minimize warps. However, they precluded the platter mat swapping that was popular back then (probably still is), and a badly warped record could still defeat the system if there was not enough suction to hold a big warp down. And of course there was the pump to deal with, maintenance and noise. The better ones were virtually silent, about like an aquarium "Whisper" pump under light load; some of the more powerful were best relegated to a closet.
I have one, a good bang for the buck.Anybody ever try Sota's clamp?
Snoop, there is another thread here from several months ago that discussed a variety of products and viewpoints. My table came with a heavy screw down clamp and I've been using the Stillpoints record weight, which has some vibration absorbing devices built into it- it definitely sounds different than the factory clamp. When I talked to Franc Kuzma, who makes my table, he actually recommended a clamp made of ebony, which he offers. There is of course the Shun Mook ebony clamp, which is quite pricey. Carl and Myles both had some input in the last thread on their experiences, you might run a search of they don't 'weigh in' here.![]()
