Yes, it is. If you use a double belt as shown you can even use two different types of dental floss!. Although when you master it, it becomes logical and simple to use.
how do you tie the dental floss together to avoid a bumpy knot ?
A double throw surgeon's knot will lie flat.
Probably very adequate for the Forsell - Peter Forsell is a surgeon!
micro any issues with speed stability or time it takes to get up to proper speed (if I recall it's several minutes with the flywheel version)?
Can you tell me the airline and fitting size data for the fitting shown in your surge tanks?
I am not sure if I can source correct metric type air fittings readily. As I am having to learn the pneumatic world, we use:
NPT – National (American) Pipe Tapered Thread
and Europe uses one of the below thread standards:
BSPT (R) – British Standard Pipe Tapered Thread
BSPP (G) – British Standard Pipe Parallel Thread
By the looks of it, the airline is about 6mm O.D.
Thanks, Francisco.
Ki
Hi,
Looking for advice on how to improve air system from Forsell gurus.
I would like to know what would be the best air pump(s) for noise and performance for both arm and platter along with regulator(s) and airline choices, etc.
Thanks,
Ki
Ki, you own Nagras and air pumps for turntable and arms!!?, you like your popcorn with lots of salt!![]()
Thanks Fransico for your reply and the photos.
The airline connectors are non-industrial type as you said. It might be for serious aquariums I guess. the difficult part for us in US is that the tubing is 6mm OD that is very close to 1/4" OD (and I've confirmed it worked as replacements) but the airline female fitting turned out to have M10 thread that is unobtainable here.
I am rebuilding the platter air bearing and separate air systems for the platter and the arm as you have done. Since I have the factory system with one air supply to be splitted into two for the turntable, i would need to source additional air setup.
However, the air bearing idea is very intriguing to me for both the platter and the arm if they work properly to float and to be isolated from all mechanical vibrations. Guess it is easier said than practically done though.
(...) The airline connectors are non-industrial type as you said. It might be for serious aquariums I guess. the difficult part for us in US is that the tubing is 6mm OD that is very close to 1/4" OD (and I've confirmed it worked as replacements) but the airline female fitting turned out to have M10 thread that is unobtainable here. (...)
Ki,
Just to add that the airline female are not M10. I was astonished a paint accessory could be metric, as almost all tubing in Europe is still imperial. Although the OD of the thread is .385 " (9.86mm) It is the same pitch as some panel RCA connectors I used recently. Thread pitch is approximately .04".
You will find it is much simpler than people can imagine. All you need is a clean continuous flow of air. BTW the Techno Takatsuki Co. air pumps (same as used in the Forsell , the Eminent Technology and several other air bearing tonearms ) are not expensive and are sold by HiBlow. http://www.hiblow-usa.com/?module=Home.
Next time I go to our local tooling warehouse I will look if they have the M10 thread fittings.
