Help me make sense of cleaning fluids!
daytona600
724
151
955
scotland
slowGEEZR
1,318
75
968
72
Colorado Springs, CO
With my VPI 16.5, I use the Nitty Gritty Purenzyme+ followed by Nitty Gritty Pure 2. It is important to follow the instructions, as it really does take about a minute for the enzyme cleaner to do it's stuff. Before vacuuming, apply the Pure 2 to the record surface where the Purenzyme* already has done it's stuff, there is a chemical reaction that you can smell, as the combined chemicals do their work. After vacuuming and before playing, a few zaps from a Milty Zerostat will remove any static. I've been using a Zerostat for many years and they work. Also, if pants or shirts stick to your skin due to static, a few zaps from the Milty will fix that, too. I'm currently working with my dealer to purchase a new Keith Monks unit (I still am not sure which one) and will probably switch over to their new fluid.
rockitman
7,097
412
1,210
Northern NY
Unfortunately, those are not in my budget. Having said that, I don't really notice any issues with static using my method.
The way to test is to put a record on the platter and look for any dust particles from a sleeve, ect. Use a photo blower ball puff of air to see if the dust just blows away. If it doesn't and just creeps along the record surface, there is some static.
Johnny Vinyl
May 16, 2010
8,570
51
38
Calgary, AB
just tried that on about 4 LP sides....there was the odd spec of dust after removal from the anti-static sleeve, give it a puff of air with a photo blower as you said.....it floated away. No static.
Fred
296
5
365
Covington, LA
Neither do I. But I also zap the vinyl with a ZeroStat and then use an anti-static brush right before cuing down the tonearm.
BobM
169
9
150
64
Long Island, NY
Personally I found I got very good results using the Disk Doctor fluid and brushes on my 16.5. L'Art du Son is also highly recommended by a good friend, but it is certainly more pricey. VPI fluid is no better than anything you could mix up yourself from alcohol, water and a drop or two of photoflow and not as effective as the others.
