Backert Labs preamps
muncybob
7
From a little research here, Bob Backert is no stranger to many of you. I had the opportunity to audition for a week one of Backert Labs new preamps...the Rhumba 1.1
I'm not sure where they retail these but if you get a chance to hear it you will not be sorry. I wish I had the budget right now to pick up this piece, but it will have to wait a bit. The clarity, separation of instruments and clean bass was an eye opener for me. Anybody have any experience with stuff from Backert Labs?
I know Bob and he makes a great preamp. I believe they have or will be having a new pre that is less expensive than their flagship model. I have contacts there that can help you I am sure.
To my knowledge they have the Rhumba and I believe the Symphony...the former being the less expensive one. Do you know if they do mods on amps not made by them?
Thanks guys, I just sent an email to Andy for some info. I have an old Dynaco PAS4 that I am considering updating. Not in the same league as the Rhumba but still a decent piece.
I was wrong on the amp they have, it's not the Symphony but I guess you guys knew that already :)
Hello,
Their reference preamp is called the Rhythm whereas the Rhumba is a somehow scaled down version. Unfortunately there is no way to listen to them in Europe.
From the reviews I read, which are all pretty raving, it is hard to make up the sound though they are in line with what you write on resolution and clarity.
The thing is: do you think this preamp also brings some warmth (not luscious but just very realistic timbre with the harmonics that go with it) to the table?
If it does in combination with the high resolution it could be a best of both worlds. If it doesn't, one might as well buy a solid state preamp...
With the ease of rolling tubes in the Rhumba, I would think you can customize the sound to your liking.
Hi any further updates on the Backert? What have these been compared to, apart from what's written in the formal reviews?
A couple of months ago I contacted Backert Labs and tried to arrange a demo in Europe, i.e. to have a preamp on trial but that didn't work out... Having to pay for the unit upfront + transport (and possibly back) + import duties + VAT + customs handling fees made it impossible to do such trial with a unit that is shipped out of the US into Europe.
In other words, if I would have decided to return the unit, then I would have lost a big portion of its value just on getting the unit here in the first place. For this reason, it is much more appropriate to look for manufacturers that are based in the European Union (at least until 2019 from a UK perspective, after which time it will become very interesting for the Brits having successfully concluded trade deals with half the world no doubt ;) )
Yes but Backert, Veloce LS-1, Exemplar WMTS, all available used at low prices if one can change it to our voltage. Unfortunately cannot listen to them or compare them.
I veer away from 'europeanized' US voltage-designs. You can get stress in the transformers and hum and no way to remedy, simply because at the origin the power circuit is designed to work well with 110V.
Of course, there are designers over there that already take the 220-240V requirements into account from the start but it is a bit of a lottery to know which ones these are.
Ok good point
The main problem is not the 110 /230V - manufacturers can easily deal with it. But the 50 Hz is a source of stress and noise in the transformers and most US manufacturers are not prepared to test their equipments at this frequency. This plague affects even well known and famous US brands!
