Ron, re steering twds warmth from a platform, as we discussed it appears Mike strives for uber neutrality at all times, and prefers not to "tailor" a sound by deliberate mix of components.
And this is the first time I've heard of active isoln introducing warmth into a setup.
you miss read my post.
using a high mass steel table top will increase warmth compared active isolation generally. the high mass will in essence change the frequency of the resonance and add a bit of warmth (less focus). active isolation will attenuate the resonance to a large degree increasing focus and articulation.
these are relative results and the actual difference is dependent on lots of variables. the musical consequences when applying these things to the new AS-2000 will have to play out. I expect they will be quite system dependent.
