Where Do You Buy Your Coffee Beans
It's my experience, if you pull your own espresso shots, that the grinder is important in order to deliver the right fineness without heating the beans. However, grain size, volume of ground coffee are related to the oiliness. Plus you need to tamp the puck properly, ideally 30 lbs of pressure - which is why I got an Espro tension tamper that delivers a consistent tamp. I find that after hitting the button on my semi-automatic Salvatore Espresso machine, there should be at least 7-8 seconds before any liquid comes out and for a double shot, it should take more than 20 seconds from start, ideally 24-28. Thus you get a properly extracted shot and good crema. Since I also prefer lattes, I steam the milk and have pretty much figured out, by holding the pitcher (or nowadays I steam milk in my big coffee mug) how hot is just right. Over 160F and the milk tastes burnt - which is what happens at least half the time when I get a drink at a coffee house. There are people who are a magnitude more paranoid/detailed oriented than me - coffeephiles are just like audiophiles. They get into factional measurements of water temp, flushing the unit first if it is a heat exchanger, etc. The king of the hill for a home unit is the La Marzocco GS3 at 6500; La Cimbili is also good. As for grinders, I have a Mazzer Mini doserless and it's awesome - the only one better, but uglier, is the Versa Dynamics (of Versalab turntable fame).
If I had to use a super automatic, like a Jura Capresso, I'd get the Nuovo Simonelli Microbar as it provides heavy duty boilers, grinder etc.
Very informative post, thanks. I noticed that Intelligentsia also recommend the GS3 - my goodness, very expensive. And my Krups delays pumping by 3 seconds after an initial 1 second pump (intentional, per the manual) - what's the thinking behind this delay? And then it extracts a double in 25 seconds; I read this is probably a very good result; what's so important about 24-28 seconds?
The most knowledgeable and dedicated espresso advocate I've come across on the Web is David Schomer of Espresso Vivace in Seattle. He apparently does consulting and has written a series of articles for the trade, in lay journals, newspapers etc. and he has a blog. Here is an article that covers the extraction time:
http://www.espressovivace.com/archives/lucidcafe/LC19.pdf
You can find a whole slew of information at his site: http://www.espressovivace.com/archives.html.
The time reveals the manner in which hot water is forced through the puck, extracting all the flavor; if it's too short it shoots through in crevices or channels and if it's too long, you over extract.
Thanks, William. There was lots of very useful information even for a home brewer. I particularly liked his introduction.
"Espresso improvements hide within each other like nested Ukrainian Dolls. Refine one factor and others appear that were affecting you, but hidden within a larger defect. For me it remains some serious fun, this pursuit of perfection, like chasing a feather in a windstorm."
coffee? cafè!
Hello,
what a great deviation!
I swear by http://www.caffemauro.com/mauro-en.php no idea, but somebody must import it
also exquisite are beans by treforze, quarta or veronesi - as you see, I am biased towards italian roasting.
I am sure there are great coffee roasters in the States, but Starbucks, I am afraid has to stay out of this quotation!
However; the real important point, just like with any good chain is the temperature control!
Nowhere better for home use than here (I am very happy owner of this machine, and it greatly added to our quality of life) So go and visit this link and be enlightened :)
http://www.absolute-clarity.com/butterfly.html
egidius
I agree. It's a Burr grinder. Very good.
The burr grinder on my Jura Capresso is first class.
Next question - what's the perfect water temperature for espresso? The Intelligentsia beans are "spec'd" for 198F and my Krups produces "only" 174F... thoughts?
you guys seem to be brewing only espresso and not regular coffee as well or am I mistaken
174F measured where, Peter? While the group head should be controlled somewhere in the 190's F, by the time it hits the cup it's likely to be in the 160-165F region. At the boiler, temp's even higher e.g. mine is set for 216F.
Check this link: http://www.espressovivace.com/archives/9211col.html
If espresso, the temp of the water coming out of the screen should be 195F or above. If coffee, I think 174 is about right giving you a cup of coffee around 165F.
I have read that the best regular coffee maker is the Technivorm as it does a better job dispersing water to properly brew coffee in the basket. If I drank coffee I would consider one although the kitchen already has too many appliances.
Are expresso machines the "What's Best" brewer? :confused:
I like the taste of French Press - but may be that's just me??? Anybody have advice on the best practices for French Press? What about siphons? Being a Chinese tea drinker, I drink a cup or two of coffee a week - Sunday breakfast usually.
It seems that all you guys are only making espresso rather than brewing coffee as well or am I mistaken
I too only drink espresso made from my Jura Capresso however everyone else in my family prefers brewed coffee so I like the versatility of the Jura Capresso
Hey Ken - excellent question. I guess I measured it at the wrong place, the cup itself (in fact, a very large cup). So the obvious next question is - on those fancy machines with the water temperature gauge, where do they measure the water temperature, if you happen to know?
Peter, the one's I'm aware of measure at the boiler and compensate for the temp loss to the group head. 216 @ the boiler as regulated by my PID controller gives 198 @ the group head. Never measured the in-cup temp. It's possible there are machines which measure group head temp, though that wouldn't seem to be the best approach.....
Best espresso is all about controlling the variables - water temp, beans, grind, dosage, tamping, pull-time, scrupulous cleaning etc. etc. Get yourself a PID and you can permanently eliminate proper temp worries. :)
Doc - yes, nothing but Espresso spoken here; and I guess Cappuccino if the guests request it.
Forgive my ignorance, but what's PID?
