User manual for CAT
Torres
1
Hi, does anyone know where to get an user manual for CAT JL2? I seem to have mislaid mine, and I think its time to check the bias settings..
Best regards,
Torres
DaveyF
6,129
181
458
La Jolla, Calif USA
If/when I try tube amps later this summer, his mono's might be the ticket if I don't go ML3's
Ken's amps are great, but it's his preamp that is the real star of the show.
CAT is an excellent alternative to Lamm IMHO. Personally, i prefer the CAT Legend Black Path to the Lamm LL1.1.
kevinkwann
134
9
925
Kidneystone-on-Trent
Nothing. I was interested in specs of his current amp offerings. I find it surprising he doesn’t have a website in this day and age.
I found this on the ‘net for the CAT JL3:
Specifications:
Power 150 watts into 8 ohms - class A
200 Watts into 4 ohms - class A
Frequency Response 1 Hz to 75 KHz (+0, -3dB)
Gain 30.6 dB (8ohms)
Sensitivity 835mV AC for full power (8 ohms)
Noise 110 dB below full power
Power Bandwidth 10 Hz to 30 kHz
Damping factor 108
Dimensions 27" x 18.5" x 10.5" (L:W:H)
68.6 x 47 x 26.7 cm
Weight 180 lbs. (82kg) each
And for the JL7:
Specifications:
Power: 250 Watts, 4 or 8 ohms, 1%THD
THD @ 1 Watt: 0.005%
Energy Storage: 1800 joules
Bandwidth: 1 Hz to 70 kHz (+0, -3dB)
Damping Factor: 14, across entire audio band
Gain: 27dB (8 ohms), 24dB (4 ohms)
Input Impedance: 100K ohms single ended 200K ohms balanced
Sensitivity: 2 VAC for full power
Noise: 120 dB below full power
Power Bandwidth: 20 Hz to 30 kHz
Tube Complement: 2 x 6922 driver and power supply 8 x KT150, triode mode
Dimensions: 20” x 12.4” x 7.8” (L:W:H) 50cm x 31cm x 20cm
Weight: 88 lbs. (40kg) each unit
Hope this helps.
DaveyF
6,129
181
458
La Jolla, Calif USA
^^^Thanks. JL7’s would be the way I wound go...
Excellent choice, and I think you would get a significant upswing in SQ over your current Pass labs.
The phono stage in the CAT preamp...both Legend and Renaissance is superb, IMO. Saves a great deal over a stand alone phono stage.
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
Best regards,
Torres
Hello Torres i have the papers that come with the cat jl 2 sign,. If you send me your email i can send you a copy.
Greetings hj
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
They are great Amps christian , i never heard the ml3 Though, but you cant go wrong with Cat and in your new big room you might use a bit of power
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
Jl 3 is 82 kg. Each. As is my stereo amp.
Jl 7 only 40 kg a piece ??
Hmm whats the deal here , dont wanna skip on Transformer s /power Banks imo
andromedaaudio
8,469
2,821
1,400
Amsterdam holland
I think the biggest gain Will be dynamics compared to pass labs, and i bet your in for a audiothrill as the Wilsons are An easy load so are my speakers
Does he still work out of his garage. He visited me several years ago with another friend of mine. Very interesting guy
