Innuos is Windows based so you can play music with any kind of software you like.
But that is far away from the thread theme.
You are entering on a never ending one.
I'm getting lost.....
Better ....... No comments.
popspin,
No, Innuos provides UPNP, Squeezelite (iPeng) and Roon out of the box.
The problem is that iPeng (Squeezelite) only outputs through the USB port, which I have no interest in. So I wasn't able to test that.
After your question last night, I began to compare Roon x UPNP on the Statement, but my first tests were inconclusive. I'll have to set up our UPNP infrastructure all over again, as I haven't used that stuff in many months. I'll do some more comparing later.
Okay. For me it would not be a problem (it would have been a month ago that I still had Lumin) since I currently have a USB DAC. But then the only way to transmit to a network music player is with ROON by RAAT and as long as it is certified as ROON READY?
Could you please tell me what OS do it use?No, it's not Windows based. No wonder you're getting lost
No need comments....Thank you for your kind words....Better ....... No comments.
Thank you.Sure. It uses a customized version of Linux.
Thank you.
I had an Aurender N100. Linux is very stable.
But i’m very surprised on the software focus above sound quality.
Regards.
Let it go....What are you talking about? "software focus above sound quality"?
With all my respect, maybe you have to learn more english and see word “you” can be used as plural. Don’t trust always Google Translator....Well if you insist ...... Apart from the incorrectness of your statement about the operating system of the Innuos (already in the post indicated that InuoOS! Is based on Unix), what really bothered me, is that you have affirmed that I I'm getting out of the thread, by asking (in an Innuos Statment thread) about the UpnP playback software of the Innuos Statement.
Tell me what we should talk about, if silver is more beautiful than black, or what is the best product to clean it without damaging it?
popspin,
Hi great description.
I agree with your point of view on the importance of noise in the network. I also give a lot of importance to try to decrease it, I use LPSU for both the router and the switch. It seems that we have come to the same conclusion; reducing the noise at the level of the router or switch improves the sound even though the transmission is from the server files directly to the DAC or Network Player.
I'm just going to give you a suggestion in case you want to try it, both my Switch AQvox and the Router are connected to Entreq boxes with Entreq cables with RJ45 connector. If you try it, you may find that the sound improves.
I'm really surprised. I did not know that ROON could be transmitted using the UpnP protocol. In fact my thought is that ROON designed the RAAT protocol, to overcome the limitations, which in his opinion, had UpnP. How does ROON get through UPnP ?.
Ok, I misunderstood the UpnP x ROON.Please read again. The comparison was Roon *versus* UPNP.
