>>Current Magico, YG, even Harbeth have reduced it to a massive degree using higher order elliptical crossovers. There is no solution for it on single driver speakers... it's impossible for a single driver to resolve clearly like a multi-way speaker can on complex music.<<
This is dated thinking. Granted, most FRDs aren't implemented to refute this, but some are. High order "elliptical" crossovers impose their own problems. Any advantage the over-resolved multi-way might have for the hungry-ear audiophile is more than negated by the damage said crossover does to holistic sound. I've heard all the multi-drivers contenders. They are all wanting. You have to actually make a more sustained effort to hear today's best FRD-based speakers.
Phil
Have you ever got to play with adjusting the feedback on the amplifier powering Magicos? I think you might find it rather interesting how much the sound goes in and out of being holistic. I'm not saying you'll like the sound, but it plays such a huge factor that I think it's pretty hard to just blame the crossover (or drivers, or box) as the sole reason for what you hear. As the distortion of the speaker becomes even more dominate, we start to hear the differences in the driver, and maybe largely (or entirely) the way their patterns work.
This is where different types of crossovers tend to fight the result you'll get, where maybe an amp might make a low order speaker not sound too much different, and a higher order one sound a lot more different. I would assert that it has to do with the way the drivers propagate waves (radiation pattern) on top of different characteristics for different drivers. This factor has given a pattern for Keith, where lower order crossover speakers sound more cohesive to him. But any way you spin, in general, we are often quick to exchange lower distortion for keeping a consistent sound. We're annoyingly sensitive to hearing these differences... It's sorta sad in a way, because lower distortion often has benefits, but we can't use them if the sound is so torn apart across the spectrum.
The part about waves propagation is my own theory (Ked).
BTW I don't think FRD's are that great. The high frequencies are rarely tolerable. They're tilted without a crossover, and with one they aren't "pure". They need baffle step correction. And even worse is the fact that the high frequencies get bounced by the low ones (the cone literally slaps them). While they can be fun, I can't sit in front of them nearly as long as other speakers. The best ones I've heard were bipolar so they didn't need BSC, and they used less excursion... (excursion is the enemy) It's probably wise to go as large as possible (15") and bipolar in a large room, with a roll off starting around where the room gain starts. Maybe I'll make some, some day.
