KLAUDiO RCM EOL
jeff1225
3,011
3,254
1,410
51
Well, devices that take part in recreating sound, and are sensitive to vibration affecting that sound, can have a benefits of weighing more. I think that relies on the design and actual materials more so though, IMHO. I got a new turntable recently that's very light yet I find it built to the highest possible degree and sounds superb. Then you look at Mike's new Saskia table which is ungodly heavy and it is also built extremely well and sounds superb. I really see no relation to actual weight making any difference whatsoever, especially for a RCM.
Well then you simply don't understand what makes construction of a mechanical device robust or not. I guess you don't own power tools.
On a happy note, maybe this will be the one piece of stereo equipment my 8 year old daughter can move around.
djsina2
1,126
964
213
Like I said, this is not an industrial tool where the rigors of use need some sort of over the top construction. I am baffled why you would think something that encounters no stress needs to be encased in a bomb proof structure. I guess this is where we will differ. I own a complete shop of tools and do amateur home remodeling on the side. I also have a hobby CNC machine and have restored cars and built engines. :D
Reactions: mulveling
jeff1225
3,011
3,254
1,410
51
If you own tools you have no excuse for your "weight doesn't matter" argument. I assumed it was ignorance now I understand it's just hubris.
djsina2
1,126
964
213
I'm sorry, but I really have no idea what you are talking about at this point. I guess we should leave it at that.
tima
5,778
6,820
1,400
the Upper Midwest
Yes, you would think so. This was therefore surprising to see how the KL could not improve it no matter how many washes yet the Degritter did with one.
What your anecdote suggests to me is not that one machine cleans so much better than another but that using multiple ultrasonic frequencies may be more effective than using one.
You can never clean the same record twice. Imo it is near impossible to base a comparison on cleaning a record in one machine then cleaning the same record in a different machine.
Reactions: jeff1225
djsina2
1,126
964
213
That is possible, but since the KL made no appreciable difference after multiple cleanings and the Degritter did I would say the Degritter cleaned better. Also, taking a new record or a record with no issues and running one through each cleaner I heard a more noticeable improvement with the Degritter. Unlikely that after 10 cleanings with the KL I got lucky and the 11th pass would have fixed it with either machine. I guess saying one cleans better than the other is too controversial for this forum so we should ignore that and focus on the other aspects. It's undeniable that the Degritter has more features, finer adjustments, has a filtering system, is quieter, is easier to fill and clean, is firmware controlled, and is much cheaper.
jeff1225
3,011
3,254
1,410
51
*and it made of less expensive materials.
rockitman
7,097
412
1,210
Northern NY
So degritter should be considered ? Looks like a toaster and not as well built from first glance. It does have 300 watt vs 200watt. I am not sure I want more violent ultrasonic action on my finest vintage LP's ??? It is $900 less than the external tanked KL. I have had no issues with the KL since day 1 (2013). It is a first or second production run unit. I'm still leaning KL although the degritter has given me more pause to do more research and hear more opinions. I don't buy the side by side listening tests as they are impossible to really do in the first place unless you artificially soil copies of the same record identically and then wash each one and compare subjectively.
Cleaning fluid in the bath is not ideal for my cleaning regiment. I hand scrub records with cleaners and micro towel dry (first time only) before going into the KL. Think of it as an ultrasoinc scrub/rinse/dry. I do change water every 30 cycles with my method.
Reactions: jeff1225
spiritofmusic
14,606
5,415
1,278
E. England
Christian, KL was a no go for the majority of UK buyers, esp w the much suspected crazy mark up from the distributor.
I remain amazed KL didn't go to a direct sales model.
W the KL at c£6k, ADS at just over £3k and Degritter rrp closer to £2-2.5k, KL had no chance here.
Reactions: Audiophile Bill
djsina2
1,126
964
213
If you don't want cleaning fluid in your water then don't put cleaning fluid in it. it's not a requirement.
rockitman
7,097
412
1,210
Northern NY
Cost isn't the issue(for me)...effectiveness and reliabliity are. Degritter is too new for a reliability track record.
Reactions: tima
spiritofmusic
14,606
5,415
1,278
E. England
I don't think so, Christian. Try again.
dminches
3,409
2,794
1,410
I will be tempted to get some of the Degritter soap for use in my KLAudio, seems a reasonable test as I have a few records that have some pops and clicks that have not gone away with multiple cleanings.
When I have this issue I find that the only way to treat it is to manually clean the record with a solution and Disk Doctor brush. I have been using L’Art du son. It works great to pre-scrub and then pop it into an ultrasonic.
dminches
3,409
2,794
1,410
Christian, it is time to build your own. Tim and I have found they work the best.
4,698
IMHO the requirements and mechanisms needed for a small size fully automatic cleaning machine in a single step are too ambitious for the budgets being considered. A reliable simple automatic machine would need to plunge the immersed part of the rotating LPs and then lift them to be dried outside the tank. Such system would however be too large for typical users.
tima
5,778
6,820
1,400
the Upper Midwest
Did you, by chance, use the Degritter cleaning solution in the water when cleaning with Degritter, or plain distilled water? Did you try using the solution in the KLAudio machine? Perhaps the effectiveness is enhanced by the cleaning solution... a tiny amount of “soap” might make a difference helping release stubborn particles.
I thought Klaudio was pretty clear about not using cleaning agents in their machines - did that change?
