Lampizator Valve / Tube Rolling Review Thread
dminches
3,476
2,848
1,410
Same here, I prefer the Taka 300b over the Elrogs 300b (old and new) in my Lampi DACs.
But the Taka 300b imho only really shines in combination with the stablemate Taka 274b recti :oops:
But the Taka recti is the real Star of that trio :D
The Taka recti makes most Output tubes shine and not only DHTs, also in the TRP with in Triode mode wired pentodes, the Taka recti Excels :cool:
That's what I listened with last night; Tak 300Bs + 274B.
I still have to try my GEC rectifier with my updated Big 7.
Reactions: christoph
Zero000
2,987
1,141
478
Just thought I'd make this point cos it's interesting.
Testing various old triodes, it can take them a while to come up to spec. Literally minutes. Like they have a sort of slow start mechanism built in.
I'm not sure if it is just because they are old or if it is by design. But it 100% definitely is a fact.
So if you're there making quick compares with the likes of new valves think again. It isn't a legitimate compare.
Zero000
2,987
1,141
478
Another thing. Thoriated tungsten filaments.
By far the strongest 211s I have are the ones I have been using for years. All the old 211s I have have thoriated tungsten filaments.
The fact that that is true and I have measured over 25 of them supports the idea that they really do replenish themselves. Rocking technology discovered years ago that should NOT be forgotten.
That said, they came out when radioactivity was the future. So unsurprising to an extent.
Zero000
2,987
1,141
478
Another bug bear. The term NOS. It means new old stock.
So much that is sold as NOS is NOT NOS. The term has quite violently been mis-used by valve/tube sellers.
If it measures NOS it is NOS (as best as you can tell these days). If it has some dodgy valve reading in an eBay listing without qualification or explanation it is suspect in some cases.
Even new valve sellers palm off valves that are well used as new. Really. Had that with some KRs.
Be careful. As careful as you can be.
wisnon
3,536
640
1,200
Chris, can you speak to the difference between the KR242 and the RK 242 (you own both) in your Pac and in the GG1 when you had it? Also, what can you say about the RK px25 (you own) vs the KR px25 which you have heard extensively on trial?
dminches
3,476
2,848
1,410
Sure, only the electrical equiv 6b4G needs an adapter. 6A3 is a straight plug in. Not for Pac or GG2 though, as those can only take the tubes on the selector, except for PX25 that works on 101d setting.
My Big 7 MKII really likes the Sylvania 6A3s. I have a pair of 6B4Gs and the adapter which I will try next.
Reactions: wisnon
bonzo75
22,643
13,675
2,710
London
In Greg's system the PX25 were better than the RK PX25 though the latter were very good.
christoph
4,679
4,072
825
Principality of Liechtenstein
Hi Norm
It is exactly the other way around.
I own both PX25 (RK and regular balloon) but didn't have the RK 242 and the KR 242 (regular pinched) at the same time.
From memory, I would say the regular 242 has a little more gain and dynamics while the RK 242 is a little less extreme (being a tad less explosive and a tad less transparent) than the regular 242.
christoph
4,679
4,072
825
How would you describe the difference between the regular balloon PX25 and the RK PX25?
wisnon
3,536
640
1,200
Hi Norm
Thanks, what about microphonics levels for the 2 versions of the 242?
christoph
4,679
4,072
825
Reactions: bonzo75 and wisnon
Jazzhead
1,466
108
985
GG1 plus 242 ... That's me done... Game Set & Match ... There's this bloke who has been screaming about this combo , can't quite place him right now , but thank you all the same
Reactions: iain and bonzo75
wisnon
3,536
640
1,200
lol. GG1 didnt work for me with 242, but b7 did work very well. After upgrade gg1 was better but still not ideal...gain still to high. On Pac, still better but sky didnt open up. PX25 better for me.
Thing is....PAC beats GG1 handily to my ears.
bonzo75
22,643
13,675
2,710
London
Both silent
I told Marty the same thing. I don't know what causes the microphony. My Lampi got very micro phonic at Justin's but silent otherwise. Bill's, dctom, with 242, very silent.
bonzo75
22,643
13,675
2,710
London
Zero000
2,987
1,141
478
No KR or EML valve I have come across is silent.
Crazy claim.
Put your volume in 10 and tap the tube directly with no music on.
Zero000
2,987
1,141
478
The game set match was against the so called Nadal, Djokovic, Sampras, etc. But when you have Federer on your side, you can live with it and win forever
http://zero-distortion.org/neodio-origine-vs-trinity-aqua-formula-and-stahltek-opus-prime/
Y
Yours was exactly the same as Robs.
Zero000
2,987
1,141
478
Ked according to Mark at Malvern Audio Research, my Big 7 had a clever valve microphony minimisation circuit.
Your GG1 (and Rob's) never had this circuit.
When my DAC went back to Lucasz they ripped this circuit out and replaced it with a circuit like (or more accurately similar) to your GG. My DAC is now as susceptible to microphony as any GG1 and my guess would be later GG DACs too.
Whilst this circuit sounds better, it is far more susceptible to microphony.
