State-of-the-Art Digital
Mdp632
431
140
173
Spectral SDR-4000SV (CD only )
EMM Labs DA2 + NS1 ( dac + streamer )
Al M.
8,685
4,474
963
Greater Boston
Hi, The Vivaldi Clock adds space, textures and resolution. Things unravel better, in it's own space so to speak and just the fineness of the resolution increases. All of this draws you into the music and a better emotional connection. It's one of those things you hear from the first note and just can't go back to no clock in a Vivaldi set up...
Thanks for the info.
Kingsrule
1,432
681
1,430
dCS vs. MSB
I had both the Rossini and Vivaldi stack and MSB SII
dCS sounds mechanical and contrived, nothing like music. Actually its really bad
MSB on the other hand is very, very musical....its the most realistic sounding digital source I have heard
I would like to compare it to the Total dac.....
Al M.
8,685
4,474
963
Greater Boston
dCS vs. MSB
Not to counter your observations, but don't you use DAC direct into power amp? If so, the MSB most likely would have a great advantage. It's preamp section is famed to be excellent and even has been reported to be preferred to any separate preamp, whereas Vivaldi direct into amp is really not so hot...
In fact, I now doubt that any DAC Direct option is really viable unless you go with MSB Select II or Reference DACs (the MSB Premier digital volume control isn't that hot either).
I now know what a really good preamp brings to a system. It's huge.
Reactions: Alrainbow
Uk Paul
516
183
955
UK
Maybe often overlooked is the top Ayon DAC, the Stratos, I'm using it with their CD-Tii transport only, it keeps me very happily entertained :) It's hard to tell apart from really good sounding analogue here..
adyc
873
399
973
No. MSB Select 2 preamp is not that great. My CH L1 beats it hands down. L1 gives much more dynamics.
Al M.
8,685
4,474
963
Greater Boston
Wow, interesting! That's the first time that I have heard anything negative about the MSB Select 2 preamp (not that I've listened to it myself; I did listen to the Vivaldi internal pre).
jespera
494
539
200
London
Weird thing about digital is that, contrary to engineering theory, the source is as important as the dac.
The digital source defines the character (soul) of the replay.
The best digital sources ive heard are early cd players.
I havent heard anything computer that id recommend.
I like dacs with tda1541 chips and valves and I love my abbas 2.1se dac. He does better models than mine though.
Jesper
adyc
873
399
973
I have compared them extensively. I actually use it without preamp first as I want to save one component. I found it lacking life and energy. I decide to add L1. It gives life back to my system.
I agree with you preamp is very important. To me, it is the most important component in the chain.
4,698
Because I believe that with digital “technically advanced” is highly correlated with more analog-like sound quality.
Well, I can't see why. Digital and analog are different views of stereo sound reproduction, although you can tune digital to sound more analog-like, it does not mean it is technically advanced.
Reactions: PeterA
4,698
I heard a direct comparison between the Vivaldi stack and the Yggy in a familiar system. I only very slightly preferred the Vivaldi, though two of my friends much preferred the Yggy in this same system. Perhaps the Yggy DAC should be on Ron's list. :) Don't ask me which version of each we compared, as these things change frequently and I can't keep up.o_O
I really liked the dCS Rossini when I auditioned it at a local dealer.
Well, IMHO the important thing would be a good description of the system and room. A comparison in another system is worthless to Ron unless their is some similitude between system or listeners preferences.
I have often told that we must tune a system around a particular piece of top digital. The Vivaldi is not an easy piece of equipment, I have listened to it sounding miserable more than once, but I have also listened to it sounding like master tape. BTW, as others, in general I would not recommend it to be used without preamplifier, although it seems that with some particular tube amplifiers it can sound magnificent.
Tango
4,938
6,268
950
Bangkok
Try an iPad with an Apple Airport in a direct comparison with any of the above and see how much you gain if any sonically by spending tens of thousands more and having to deal with constant complications and never ending upgrades that are simple to do inside the Apple eco system. Yes there are differences in hifi values but musically computer sources all share the same inherent qualities and short comings no matter what you spend, IMO.
david
You are ruining the market sentiment here khun David. Here is a bunch of people with a lot of disposable income. We are trying to figure out where to put money to beside those investment funds. Think of this as a generous support to the audio industry. Only that when we buy we should buy from a friend so some money would still be in the circle instead of 100% to those suckers. :D
16,017
13,347
2,665
Ron, are you referring to the digital audition at Mike's as the same visit during which you compared his three amplifiers? I recall that was a fairly lively discussion.
It was far from a digital audition. Digital was playing only in between more serious analog listening.
Still, I found the digital I heard very briefly at Mike’s to be the least offensive and the best-sounding digital I had heard.
LL21
14,411
2,509
1,448
Ron, there are a number of dacs that i would rate highly if you are looking for an organic, rich, analog sound (in no particular order):
1. Total Dac D1 Direct or D1 Twelve
2. Lampizator Pacific
3. Metronome C8+
4. Zanden 4 box dac
I am not a fan of DCS nor Esoteric but i have not heard them in a while. The Scarlatti was absolutely awful imo.
I have to say after all these years, it is nice to see the Zanden still being raised in such such august company. I have not heard any of the others...the only one i have heard from this current generation is the Vivaldi which i have heard on multiple systems over the years but drawn limited conclusions as there too many variables.
Jesper
You're not the only one, we like these exact things too :D
16,017
13,347
2,665
FWIW Ron , Joseph Cali recommends to me the Innuous Statement with MSB Reference. I currently have the low end of dCS in the Bartok, really like the sound and dCS is very well made. He is a dealer for both. However Comparing is not possible for me as The entire system is being replaced. Too many heavy boxes all at once, I will go with what he recommends.
Joseph Cali knows his stuff. Anything from Joe is a very solid recommendation.
It’s interesting that he matches the MSB Reference with the Innuous Statement, rather than the Select.
16,017
13,347
2,665
david
Maybe I will find an old Radio Shack 1/8” stereo plug to RCAs wire and connect the iPhone to the line preamplifier and play Qobuz and just tell everyone it is a super expensive streamer going into a super expensive DAC?
ddk
6,261
4,040
995
Utah
Even better! But iPads do sound slightly better than iPhones, I think it has to do with the cellular electronics of the phones.
I'm not kidding!
david
ddk
6,261
4,040
995
Utah
Ron needs to finish his house first! :D
David
Reactions: Ron Resnick
