What is better? Both media have their issues. Don't tell me that analogue is perfect, you do know it is not. And digital has walked forward for better, where I put two songs, one at my Linn LP-12 with a MC cartridge Denon DL-103R and my dac. Adjusting the level equal, using a SPLM. Having both at the same time, and just switching between them, most of my friends, can not tell a difference...usually they choose the digital side, does this tells you something?
I said that I do like both media, this does not make me to be on either side. Right now, due to the easy way to switch between recordings and songs, I am listening more my dac. What I am telling you is to open your ears now, digital is not that bad that you keep saying. The format is not 44.1Hz @ 16bits, it is at 11. 28MHz @ 32 bits. I am not playing any CD. I can play with DSD, the files just out of the recording console, no compression, no equ, no filters, no down a thing in conversion the audio signal. I am going to take a pic where you can see the sampling frequency of the signal and the output...
Happy listening!
