Gryphon Antileon Signature or Antileon Evo
davros
12
1
298
Hi All
I have an opportunity to buy a Gryphon Anitileon Signature or Evo amplifier, stereo. As I have no ability to listen to either model, wondering if anyone has compared the two and if so, could describe the differences?
The Evo is significantly more expensive so trying to work out if the cost is justified.
Thanks
davros
12
1
298
Also, would you pair it with either the Zena or Pandora preamplifier or go with another preamplifier?
Vienna
Go for the Evo if you can.
i think the Pandora is a very good pre amplifier, I know that some members here would propose you other options.
check CH precision too, I had listened Ch pre with a Mephisto and it was superb too.
Down Under
195
46
333
You won’t go wrong with either power amp.
I had a Colosseum and in my system the Evo is comfortably better.
Mine is mated to the Mirage preamplifier and is a stunning combination.
Pandora and Mirage have more balanced inputs if that is important to you.
Obviously there is a synergy with the Gryphon preamplifiers.
han_n
66
144
120
67
Surabaya, Indonesia.
I have previously owned the Pandora - Mephisto (stereo) combination, which is very good. After that I have changed to CH Precision L1 - Memphisto (stereo) which made it superb indeed. Not much later I changed to CH Precision L1 - M1 stereo (which could not get me to forget the Mephisto), later again I changed the stereo M1 to two mono blocks M1.1, and only after this change I was sure that I had a better overall performance. (Possibly the Mephisto solo would make the difference smaller again). So to my opinion Gryphon power amps are right there at the top of SS amplification.
Reactions: Vienna
Vienna
Hi Han_n
it is funny because back at this day, at the same studio with the same speakers and the same source, I had listened first to the Mephisto with Pandora, then to the Mephisto with the Ch preamp and lastly to Ch preamp with the Ch Stereo.
for me the Mephisto Stereo was clearly the winner. I went for the Pandora due to the fact that both components were from the same manufacturer
han_n
66
144
120
67
Hi Vienna,
Well, I do not dispute what you are saying. For me it took the M1.1 mono to beat the Mephisto stereo as well. The Mephisto stereo is still a very good performer, and I can imagine that you may prefer that one over a stereo M1. These two are top performers, and you can't really go wrong with either one. Personal taste will come into play as well. As mentioned, I never had a change to compare the Mephisto solo to the M1.1 mono, likely the difference would be smaller.
Never mind, for those asking about Gryphon power amps, I can only give the thumbs up. (I'm using Gryphon Power to power up my bass towers)
Now if you ask me about the comparison Pandora - L1, the outcome is clearer, but you didn't ask, so let's focus on the power amp;).
howiebrou
2,794
3,649
1,470
I had an audio note (UK) preamp mated to mono Gryphon Colosseum Amps. Superb combination. I find Audio Note and Kondo preamps mate very well with solid state power amps. I have tried them with Goldmund, Soulution and Vitus amps as well.
davros
12
1
298
Han_n
I’ve owned the L1 so know it well, what are the sound characteristics between the L1 and Pandora.
I also know the M1.1 amp very well and find it to be a brilliant amp.
My only reason to change is both personal and a system matching requirement.
Vienna
Interested too in your observations betweenGryphon pre and power vs CH.
At this level, it’s all about personal taste as I don’t necessarily subscribe to something being better, more different based on system, music genre preferences and taste.
Howiebrou
Great amps. Out of interest, what Audio Note preamp do you have?
howiebrou
2,794
3,649
1,470
Han_n
Vienna
Interested too in your observations between CH pre and power vs CH.
Howiebrou
long gone but it was a M77 from Kondo. I think adding a tube preamp to a SS amp can sound very good.
han_n
66
144
120
67
@ Davros
"I’ve owned the L1 so know it well, what are the sound characteristics between the L1 and Pandora".
The immediate difference I found is better transparency, in fact it is quite obvious from the moment you listen. (just a bit more open, better defined, better detailing) The difference between the L1 and Pandora is obvious. The Mephisto however is much closer to the CH Precision power amps, and could be a matter of taste. I don't know about matching a L1 with an Evo, but I do know the match between a L1 and the Mephisto performed just wonderfull, and clearly gave a better result as compared to Pandora/Mephisto. I had my son coming over, he also immediately confirmed what I was hearing. Of course, all will depend as well on the ability of the rest of the system to reveal the differences.
Hope this helps.
Reactions: goodsource
nirodha
690
307
1,625
715 kg.:oops:? Awesome. Have you got a pic?
amadeus
312
381
255
I have owned and used the Gryphon Mephisto Stereo very good power amp and also the Pandora preamp which is a good preamp bit not really in the league of state of art in my opinion.... I believe that the guys of gryphon are masters in making poweramps but not in preamps preamp designing is another cup of tea.
I have used the Mephisto Stereo whit Robert Koda K10 preamp and that was a wonderful match.
han_n
66
144
120
67
There are many pictures on this forum, however at this moment I'm forced to sell as a result of the prolonged effect of the Corono Pandemic on my business. I hope to be able to buy into my hobby again in due time. The only item not put up for sale is the table/rack. (Shipping costs would likely exceed the cost of the rack) ;)
Reactions: nirodha
nirodha
690
307
1,625
Take care and the best of luck!
