GrooveMaster II Tonearms
shakti
1,437
2,396
480
Cologne, Germany
Easy VTA is a good one (and can be bought on Ebay), I do use it for all JELCO compatible products, like the Audioquest Tonearm.
shakti
1,437
2,396
480
Cologne, Germany
Reactions: Jamesdonahue
sonyfan101
10
3
70
28
I am trying to decide between a 12" Groovemaster, Schick or Bokrand for my 301 project.. to use with EMT and SPUs. I know some friends here own at least 2 of the 3. I am leaning towards the Groovemaster for their after sales service and ease of adjustment.
I know comparing tonearms is a massive PITA but anyone have any comments on how these arms stack up sonically?
Solypsa
1,811
1,400
275
Seattle
www.solypsa.com
Are you in a position to compare? I have some opinions, but planning an actual shootout would be educational and include your own personal preferences.
Armboard prep for the GM and Schick is similar...
Jan 18, 2012
2,369
2,466
1,475
Drobak Norway
Theyre both easy enough to operate, but Ortofon lift is shitty so I bought FR lift from Audiosilente..dropin replacement with 14mm dia...
Easy VTA for Groovemaster can also be used for Bokrand with a thin sheet of something as "spacer"to fill 0,4-5 mm dia diff
defride
307
199
1,185
Also take a look at the Timestep arm. Same DNA as the Groovemaster, they're made by the same OEM manufacturer but there are differences, can't remember think it's the anti-skate
sonyfan101
10
3
70
28
I decided to go for the Bokrand arm. As far as gimbal designs go it appears much better value for money than the other two. Very disturbing reports of poor QC by Schick as well
nemu
10
16
83
The Timestep tonearms are also made by Audio Creative in Netherlands.. As far as I know they are identical to the Groovemaster tonearms you can buy direct from Audio Creative. The only difference I know, ist the length of the timestep tonearms which slightly differ from the length of the tonearms Audio Creative offers. Since 2019 the Groovemaster ist deliverd with an own custom made tonearm lift. Not with the Jelco tonearmlift any more. The Timestep arms seem still use the Jelco lifts.
The Timestep tonearms are available in the following dimensions:
• T-609 The 9? version can be used in many applications and we prefer it to both the SME 309 and SME V. This version is eminently suitable for new SME, Avid and Michell turntables and to upgrade many others.
Effective mass 26g Pivot to spindle 214mm
• T-610 The 10? version fits many classic Japanese turntables and outperforms the discontinued SME 310.
Effective mass 28g Pivot to spindle 240mm
• T-612 The 12? transcription version is recommended for the Garrard 301, 401, TD124, L75 and many others. We think it’s better than the SME 312S and the SME V12
Effective mass 29g Pivot to spindle 290mm
The Groovemaster tonearms have the following length:
Compare the length in mm of Timestep and Groovemaster arms.
Additional as a special customer service, the guys from Audio Creative will build you any length you want. Just ask them.
Best Regards
Stephan
Reactions: shakti
Jan 18, 2012
2,369
2,466
1,475
Drobak Norway
Can you give us an update on the Grovermaster. Are you happy with this tonearm?
hi
yes I´m very happy with both the build quality, handling and sound
actually considering buying another for my upcoming daVa Fc 1A
then it will be ordered with the extra pair of cables for the Fc voltage...
in my opinion the EasyVTA is a necessary extra....
highly recommended
Solypsa
1,811
1,400
275
Seattle
www.solypsa.com
The GMII is almost without peer in this price range and a very well built arm. If you want higher mass and under $3k not much else to look at, certainly not new arms at any rate, imho. (Caveat: I don't know how much the Bokrand mentioned above sells for ...)
shakti
1,437
2,396
480
Cologne, Germany
Reactions: nemu
defride
307
199
1,185
Best Regards
Stephan
The Timestep includes a magnetic anti-skate arrangement which wasn't available on the Groovemaster when I was looking a couple of years ago, don't know if they've integrated it into the design since.
I didn't get to hear a Timestep or Groovemaster in a known system but some I know did, surprisingly none of them kept them long, respectful but not glowing in their praise.
In terms of modestly priced underrated arms (and if a detachable headshell isn't a prerequisite) Funk Firm, FXR-3 is fabulous.
nemu
10
16
83
The Groovemaster II also has a magnetic antiskating.
I have two Groovemaster II tonearms, which I am very satiesfied with. My second Groovemaster replaced a Schick tonarm I had before.
For this price I do not know anything better listening to my Ortofon SPUs. It is specially made for cartridges with a low compliance, like a Ortofon SPU. The build quality is great. I personally did not see any second hand Groovemaster tonearms on the European market yet. All the people I know of having a Groovemaster a very happy with it.
Here a link to what Art Dudley hast to say about the Groovemaster II:
https://www.stereophile.com/content/listening-182-audio-creative-groovemaster-ii-tonearm
@defride
Looking at the technical data of the Funk Firm tonearm you mentioned, it does not seem to be made for SPU or other cartridges with a low compliance.
Solypsa
1,811
1,400
275
Seattle
www.solypsa.com
