And some people just have to trow tubes at anything indiscriminately
They are too opinionated and biased. It is not about the actual sound they hear
always enjoyed MBL 101's. my only quibble seemed to be that they were not happy at moderate SPL's, and needed to be played just slightly louder than my comfort level to get traction. i have never been the one with the remote in my hand in those cases, so likely living with them is different.
easy to understand their attraction.
Yes, and add to that a metallic "sheen" to the sound that once heard cannot be unheard. So despite their apparent transparency and room filling soundstage they simply have this coloration that I could not live with.
I have used Virtuoso too, but prefer Crescendo 2, even the Original Crescendo are a little tame in my system. Older Krell amps have a metallic sheen in the treble that you don’t hear on electrostatics like Martin Logan, but need taming on MBL’s.Only in inappropriate systems or rooms. That characteristic sheen is really horrible, but once we managed to get rid of it they sound magnificent. I once was trying amplifiers with the 101b with the help of a friend and, for example, at that time in my room a Krell sounded metallic, but a french amplifier that was not very expensive sounded sweet and full bodied with plenty of presence. Apologies I can't remember the brand.
I must say that I never listened to a decent show demo of them - the best I listened was in an acquaintance room completely paneled with natural wood.
Cables were also very important - the old Straightwire Virtuoso SS was my choice at that time.
Ha, funny...except I have ONLY heard them with the big MBL monos...Yes that’s what happens when i underdrive them with most tube amps, or place them in a to small room
BS.This is exactly what happens to Under driven panels as well, with tubes. And you need good SS to get past it.
You where just missing your tubes, if Ron’s car ran out of battery he would insist they used a tube device to charge it. You would insist they use a SET chargerHa, funny...except I have ONLY heard them with the big MBL monos...
Where do I buy this device?You where just missing your tubes, if Ron’s car ran out of battery he would insist they used a tube device to charge it. You would insist they use a SET charger
One of my phono stages even uses tubes in the power supplies ! It’s being repaired againWell, there is a well known turntable that uses tubes to drive the motor ...
I’m sure big VAC and VTL amps can do it with no problemWhere do I buy this device?
Wait mine are starting to sound metallic ! No it’s just the lifelike shimmer of cymbals from the 2 drummers playing on Willie Nelson’s “Teatro”I have had these speakers for years and never heard any metallical coloration. Don’t even know what it is.
get great transparency to musical performance, electrostatic clarity in the midrange, but better on the extremes... near horn dynamics... just pure joy
They do need a room with a lot of absorptive and reflective surfaces. If the room is not up to par, it’s bad news... a lot of guys use SMT wings to delay the waves that come from alll over and help with imaging ...
amp-wise, if someone doesn’t use MBL amps because of Ss allergies, cost, or something else, the consensus best is symphonic line kraft, which is the least ss sounding amp ever...may be used with a tube preamp, which is a great thing to many.., the others amps sound soft and can’t get the melon to sound right.. most amps sound like a pussy....and I’ve lifted a lot of amps before , screwed over my back, cut my hands... just knocked off the toe nail on the big toe... hurts like a b!tch, ouch!!!
like everything else , it’s about personal preference in this hobby. Things move you or don’t.
I do usually try to aim for the less vulnerable bits when I’m in a tube throwing fitAnd some people just have to trow tubes at anything indiscriminately
. . . MBL is hit or miss at shows . . .
All depends on speaker choice ..Efficiency and impedance curve / dip .
I ve said it 10000 times what you wanna see is a graph of the impedance related to freq , 20 hz - 20 khz .nominal doesnt tell shit
Plus a honest measured efficiency , i d rather trust the stereophile measurements .
I believe lagonda has the mbl radialstrahlers which are a prime example .
Efficiency of 81 db and a impedance dip to 3.8 ohms which is not too bad actually
To get reasonable dynamics out of such a design is extremely hard and requires enourmous amounts of power .
And even then it will not have the dynamics of a good designed high eff. Speaker .
My listening sessions lately of magico Q 5 only confirmed that
Slow speaker constrained dynamics .
Ps i am aware the radiastrahlers can obviously do things a standard cone cant , im not dismissing anything
