Micro...your turn
Really???
I seriously doubt that
The S/N’s on my ML3 are
G10017 and G10018
The S/N for my LL1 are J10007 and J10008
Mine are also twins. The serial numbers are stamped on the crates, but they are now boxed and the LL1's are on top ... I think 10015 and 10016, but I have to check on the documentation.
those are the numbers i recall.
Mike or ALF,
Do you remember if there was any difference between the stands for the power supplies and the amplifiers? As far as I can see they are the same.
The same, interchangeable.
And probably increasing your profitThanks. Although Lamm ML3's owners did not feel any interest on the SRA's, some ML2.x owners have questioned me on them. As the amplifiers have the same footprint, probably I will split the set in two pairs, creating two different happy owners!
Sorry, they are not the same; definitely not interchangeable...they are tuned and labeled specifically for different ML3 machines. One for the power supply unit and the other one for the amplifier.
Also, they are not built for the ML2.x amplifiers...simply, not a fit.
Interchangeable, not at all...
vbw,
-a
Yes, there is a different tune spec for the psu and amplifier units...that is the SRA way .
The top plates are the same for the footers for both units, as they are designed with the same layout by Lamm.
Mike, I hope that you did not get them mixed up...it would make a qualitative difference in performance
vbw,
-a
That explains it all ! Lamm is still king and the earth is still flatdid you read my post?
vbw,
-a
