Shunyata Research - New Products for 2020
GSOphile
569
353
173
Caelin Gabriel's characterization of the Everest 8000/T from another site:
"[Triton v3] dynamics and refinement
[Typhon QR] power & 3D spatial qualities
[Denali v2] silence & noise reduction
[Denali 6000/T] tower format w/integrated base"
_______________________________________________
The US MRSP on the Shunyata website is $8,000. I think they are going to sell a lot of these.
stevebythebay
242
119
948
Plan on auditioning this in lieu of my Denali v1 + DPC-6 combo.
kennyb123
856
796
1,155
Kirkland, WA
stevebythebay
242
119
948
Not at all clear what this will be, but Caelin is suggesting it applies to the Denali S2 rack based, rather than any other Denali product (like my tower version). Also, it seems likely a version of the Everest for rack use may be coming in future months.
Bar81
129
20
98
stevebythebay
242
119
948
Sorry. I misinterpreted what Caelin was suggesting. Whatever is coming is tied to the S2 rather than any other Denali product extant.
kennyb123
856
796
1,155
Kirkland, WA
I’m pretty sure he said that there wouldn’t be.
BlueFox
1,709
406
405
On another forum he has said multiple times no rack version.
kennyb123
856
796
1,155
Kirkland, WA
Mdp632
431
140
173
As an FYI, Caelin has been teasing a companion device for the Denali power conditioners. He hasn't been sharing many details but it sounds a lot like a Typhon-like device for the Denali.
https://www.audioshark.org/shunyata...ter-heights-18193-post-302484.html#post302484
@kennyb123 Time will tell if Denali V1 owners will able to use this upcoming product. Or, will it be exclusive to the Denali V2 only.
Most likely V2 owners and gives them a chance to add-on Everest like performance at their choice minus the 2 outlets.
Btw, Everest looks like a game changer. Was clearly expecting it to retail closer to 10K.
kennyb123
856
796
1,155
Kirkland, WA
As a V1 owner, I have been paying close attention to Caelin’s comments on the “companion” product. When asked to clarify whether V1 owners can benefit, his answer has been “Denali 6000/S”.
It could be that this product is still in development and he doesn’t yet know if V1 can be supported, but I seriously doubt that. The V2 doesn’t have any kind of connector that would allow a companion product to mate with it the way the original Typhon could mate with a Triton. So maybe it’s like the Typhon QR in that it can be plugged directly into the wall.
Alternatively, the companion might plug into an outlet in the Denali. That’s maybe where we’ll find that differences in the V1 and V2 result in the companion providing greater benefit to the V2 than the V1, thus still making the V2 a compelling upgrade for V1 owners.
Pure speculation here but I’m remaining optimistic until I hear something specific that blows holes into my reasoning.
Reactions: Mdp632
SCAudiophile
1,156
435
1,205
Greer South Carolina (USA)
That is what I heard; you should ping Caelin or Grant or perhaps they will answer here.
thyname
131
108
130
N. Virginia
A dealer told me Shunyata has just released the new version (v2) of their Sigma XLR intereconnects. MSRP of $5,000. However, I don't see anything on their website. Anyone knows anything about this?
Bluedog
37
16
140
70
Boston
I emailed Richard at Shunyata about the new Alpha V2 speaker cables. He mentioned that they weren't available until August due to demand on the plant to produce the new V2 power cables. The new V2 speaker cables weren't on their website either.
Reactions: thyname
sbnx
1,182
1,328
290
Bluedog, you seem to have omitted your speakers from your list of equipment in the signature.
I am about to pull the trigger and order an Everest.
Bar81
129
20
98
The Everest is really impressive - and I had a Triton v3 previous. I knew from within the first few notes and was sold 30 seconds in (and I went into it fully expecting to come away unimpressed and save $8k). There's no burn in - plug your components in and let them warm up and you're gonna hear what it can do in all its glory. If you are going to use a new PC however that will need to burn in.
This may not make sense but the Everest isn't a "wow that sounds awesome" product; it's a "so this is what my system is fully capable of" experience. All that with the Everest only being used with my front end and not using Shunyata cables (my front end is VH Audio PCs - Trans from the wall to Everest and Airsine for the transport/DAC/pre).
sbnx
1,182
1,328
290
Bar81, I see you are using CAD for ground control. I assume you are using this for signal ground. Are you using the Everest for AC grounding? What are your thoughts on the CAD? Did you compare to some of the other products such as the Nordost?
Bar81
129
20
98
I'm using CAD GC1s for signal ground for my front end components (started with sharing a single GC1 for my transport and DAC which resulted in a clear performance improvement and then moved to a GC1 for each component which was a substantial improvement. I also have an additional ground on my preamp via the Acoustic Revive RGC-24). A GC3 is used for AC ground connected to the Everest and also each outlet my monoblocs are plugged into (the M400s are not connected to the Everest). I'm not using the grounding system in the Everest other than as a means to connect the GC3 to the Everest.
Haven't tried the Nordost products for a couple of reasons. First, I was out of the US at the time with no dealer and CAD offered me 30 days to try with full refund - I liked that confidence in their product and I was a skeptic at the time regarding grounding products so I didn't expect to keep it. The second reason is that no grounding product other than CAD had anything approaching an explanation as to why/how their product works. The CAD white paper here is what ultimately made the difference for me: http://www.computeraudiodesign.com/CAD_Ground_Control.pdf
thyname
131
108
130
N. Virginia
Yet, dealers have access to the pricing of v2, interconnects and speaker cables, and can take orders now. Go figure. If you ask me, very confusing from Shunyata Research company part. And weird
GuillaumeB
267
85
333
UK
www.boyeraudio.com
My understanding is that the V2 signal and digital cables will launch in August. We have received pricing details from the US but will not load these up onto our website until the official launch. In any case we do not yet have all the details, photos etc. When customers enquire about current generation cables we are now making them aware of this.
I can confirm that we have been exceptionally busy with the sale of V2 power cables and have just launched our V2 UK Denali and Delta D6 power conditioners. The factory is so busy we often have a 3 week wait before products can ship.
In the meantime here is a video we recently commissioned entitled "The Art of Noise Reduction", enjoy! Turn up the volume if you can. ;)
Cheers,
Guillaume
Reactions: thyname
