It looks to me as though it sees a short, as spec'd. Either that or tell me how to modify the above circuit.
This circuit isn't right. To correct it, R2 must arrive at the + input and R1 is in fact the cartridge itself.In that case, the cart sees nearly a dead short across frequency. Well under 1 ohm at 20k, and maybe 5e-4 at 20 Hz. Note I chose this low noise opamp with 20k input Z, as you can see, but it could be anything.
Yes, that's the virtual ground. I've never asked what a virtual ground is. Circling back, then, it does seem clear that the impedance seen by the cart is not 1000 ohms, but some impedance roughly approximating a dead short.
To simulate that, put a wire in the schematic from the output of the cartridge to ground. Let's see how it works then. In the simulation, am I seeing this correctly, that the cartridge is being depicted as a 1 ohm resistor? To be more accurate, it should be an inductor of 5 ohms impedance or so.dead short
Folks, we have a small competition going:
Who is up for the iPhono3 Black Label #NoiseFloorChallenge?
Have a chance to win a prestigious iFi audio PowerStation for taking part! Find out more and how to enter HERE!
Entries close 31st July!
Who supplies the Black Label phono to us to check?
Best.
I received my Accuphase C47.
It's above my old Esoteric E-03, but C47 is very sensible with the turntable.
With VPI Classic 3, the differences between E-03 and C47 are very similar...
With Technics SL-1000R , the differences between E-03 and C47 are enormous...
For the two turntables, I use Audio-Technica ART-9.
congrats - I luv my C-37. they are similar, so the C-47 will take about 100 hours to fully open up.
It would be very interesting to compare sound of C-37 to C-47.
