Anyone with big, high current amplifier(s) find a power conditioner that doesn't destroy the amplifier's virtues? Is it even possible? Which Ones?
Kingrex
2,909
2,389
350
Do you guys plug your amps in the Torus. A friend just got a Stromtank. He was told not to put his Dagostino M400 amps through it. Amps direct to wall. All front end gear through the Stromtank.
LL21
14,423
2,516
1,448
Yes, we plug our Gryphon Mephisto into the Torus AVR16. However, I should note that we did NOT do this until AFTER emailing and speaking directly with the designers of BOTH Gryphon and Torus with the specs of each piece of equipment. Both confirmed they were happy for us to try, and we did.
Reactions: sujay and timztunz
Forte
95
66
148
Can you share your opinions (+/-) of having the Mephisto plugged into the Torus?
LL21
14,423
2,516
1,448
HI Forte,
Happy to share my own personal experiences with the obvious caveat that our main power supply of course is probably different from that of others here. So a few things:
1. We do have the system on a separate circuit with dedicated Furutech outlets. We tried to put some basic infrastructure with a Uninterrupted Power Supply as well (mainly to protect the system if the power suddenly goes out...the system won't 'BOOM' when the power suddenly cuts out). The power did go out, and the system did not even blink...kept playing, and it allowed us plenty of time power down...the UPS actually could have gone another couple of hours apparently.
So it should not have been a big deal to add the Torus. In fact, I did it mainly because I liked the protective circuitry in case of power surge or other things long-term...and felt a small improvement would be no bad thing either.
2. That said, when we put the Mephisto into the Torus, we got (of all things) a surprisingly MUCH cleaner upper bass...completely unexpected. Overall, the presentation tonally had no changes, but it did seem to present a meaningfully more detailed, crisper upper bass. And this 'clean up' gave the whole presentation a cleaner more realistic appeal. Across the rest of the spectrum, it did SEEM like the whole presentation was overall more natural, more effortless. But the main change was the upper bass where frankly, was shocked there was that much in the upper bass to improve with such a 'simple' change.
3. We do not play at loud volumes...though we DO watch action flicks at pretty high volume. So we have not tested the system to its limits...but again, the manufacturers have assured us that this setup should be fine from a technical perspective. We have certainly witnessed NO limits on macro-dynamics.
Hope that helps.
mtemur
1,406
1,345
245
48
the only AC power conditioner that doesn't kill the sound or diminish the energy of amplifiers is Synergistic Research new UEF line. especially the bigger models. on the contrary they improve energy/dynamics of amplifiers like a super-capacitor.
Torus is also fine but I only listen to the big ones and very expensive.
Stromtang is ok. again I only listened to the biggest model and it's very expensive.
Audio Consulting isolation transformer is incredibly good if you connect it's input to two phases of tri-phase power line and it's output to Synergistic Research power conditioner.
from my point of view the best and the most economic option is using a Synergistic Research PC 12 UEF SE power conditioner.
sbnx
1,200
1,346
290
the only AC power conditioner that doesn't kill the sound or diminish the energy of amplifiers is Synergistic Research new UEF line..
By "The Only" I assume you mean only the SR out of the ones you actually tried.
Kingrex
2,909
2,389
350
Try Addpower Symphony and Electraclear. They are parallel devices. Not a filter. Dynamics with no glare or stridency. Its just faster and sounds more real. Only about a $450 Investment.
Phillyb
152
112
948
Furman Reference 20i, use the high current outputs, and you are done. Drove my 400-watt McIntosh amp with no problems in fact it sounds. Stay away from balanced designs they work OK for front end gear, but for all the ones I've tried they thin the sound out, and some gear does not like a balanced current. If anything you could go with a PS Audio regenerator, I used P-10 would be a great option, but for amps, I still get a Furman.
Phillyb
152
112
948
Furman Reference 20i drive my 400-watt amp with no issues at all, in fact, it sounds more dynamic with a bottom end pop that I never expected. The power cord on the Furman was key, so a good high gauge power cord, like the 7 gage Pangea 9SE Mkii worked fine the Furman did the rest. I would imagine the Niagra 7000 which is designed by the same man who designed the Furman would work also, in fact, both units weigh the same. Others I tried were a BIG no go, one was a big name one with sales hype, and one you see for sale all the time on Gon.
sbnx
1,200
1,346
290
I don't quite understand this statement as the Furman is a balanced power device.
Phillyb
152
112
948
The High Current outlets are Linear Conditioning. The others are semantically balanced for low-level gear from streamer and anything else that does not have a need for high current voltage needs, this totally isolates the amps needs from effecting low-level gear, each of those banks is totally isolated from the other. The unit has a huge Isolated transformer and weighs a ton.
RogerD
3,734
319
565
BiggestLittleCity
I learned something in a wholesale - retail parts business a long time ago...never be constricted at the trunk of your connection that customers access your business. You might think your system is adequate but....
I think it's the same with high powered amplifiers. Your electrician may say 12 AWG is fine,but in my experience it is a waste of money. I use 10 AWG and for my new sub panel the feeder from the main panel is 2 AWG and everything is copper. I got my ass chewed by two different electricians...ROI blah,blah....the labor is the same,and it's my system. FWIW
Reactions: rugyboogie
plasmod3
566
425
138
44
shunyata everest mate! it doesnt limit the amps
LL21
14,423
2,516
1,448
Did you get the Ypsilon SET 100 Monos in as per your signature block? How are they?
plasmod3
566
425
138
44
i got the hyperions atm and they are sweet as:) set100s arriving in jan and i was told they are going to be a delight - looking forward to it Lloyd:)
LL21
14,423
2,516
1,448
Fantastic! Be very interested to hear what you think of them...have heard the mighty SET100s before but not in a system I knew well.
Cellcbern
1,224
728
585
71
Washington, DC
AdamZ
66
15
140
Germanny
Hello Guys.
I allways try to keep it simple. And sometimes it works good. ;)
So i seperate the power amp from the rest of the system.
CDP, Preamp, DAC get the power from Mains independent power supply. This is the one i use.
https://www.cyberport.de/?DEEP=6G01-53S&APID=21&msclkid=2c5c2509991c142b8814454ec9a98bca
Poweramp KRELL KSA-200S pluged to the wall. Thats it.
First try this solution for roud 100 Bucks.
After this you MAYBE choose another expensive solution.
In my case it whas fine.
Adam
