Denafrips product owners please fall in
Abyss Man
224
168
50
Hi, my first post here.
Since you tried all combination, can you give a score or in term of % for each.
1. Stand-alone Termy
2. Stand-alone TP
3. Termy+Gaia
4. TP+Gaia
If possible, can you describe the sound difference between stand-alone TP vs Termy+Gaia.
I'm Terminator owner, still deciding on how should I upgrade.
Hi,
Please have a read through this thread and my post on the 1st of August. Enjoy.
https://audiophilestyle.com/forums/topic/59219-new-dd-converters-from-denafrips/page/4/#comments
richard_crl032
107
45
113
61
Singapore
2. Stand-alone TP
3. Termy+Gaia
4. TP+Gaia
Hi Acholate,
I will say go for the TP .. early converter from standard TP to Tplus here.
Ymmv since all system/source dependent and your expectation as well as past experience but I will attempt to spend some efforts to answer to your queries in arbitrary ballpark manner:
richard: say 75% as basis for below rating to theoretical 100%
2. Stand-alone TP
richard: 90% when in single synced clock and 85% without ..details, transparency and PRAT .. more so than standard T and midbass/bass tightens up to tuneful manner aka PRAT and hear more of EVERYTHING aka details and transparency
3. Termy+Gaia
richard: no experience since standard T gone before Gaia and hence no comment
4. TP+Gaia
richard: Only needed for sources without clock input from TP be daisy chained else direct to TP please ... 85%
Hope this helps.
Cheers.
Richard
Acholate
2
33
Hi,
I actually read your post at AS already, which is very useful. But I want to know sonic difference between Termy+Gaia vs stand-alone TP. Is TP better in everyway? From what I read, Gaia will bring in 3D and holographics, while TP more detail?
Hi Acholate,
2. Stand-alone TP
3. Termy+Gaia
4. TP+Gaia
Hope this helps.
Cheers.
Richard
Thanks! This is exactly kind of answer I looking for. Just miss out your experience on Termy+Gaia.
Both of you seem to like stand-alone TP more than Termy+Gaia. But I'm not so sure whether I will like TP. I afraid too much detail will make my system too bright.
richard_crl032
107
45
113
61
Singapore
Hi Acholate,
Most welcomed .. you cannot change a standard Terminator to a TPlus with any DDC .. someone here tried and was reportedly fine but also ended changing .. ...
In my opinion, the DDC can improve non i2s and non oxco clocked sources but only below a certain level like my sgd450 allo usb bridge signature but not my 10x $ Antipodes also via usb.
Btw, Terminator is not bright but neutral while indeed detailed and transparent and will not make your system bright sounding unless something else in your system is bright sounding. In fact, its tight but bodied midbass and bass at least in my system is what I deem outstanding because it improves PRAT or what I term as enjoyable boogie factor.
Hope this helps further.
Cheers.
Richard
Koso
12
18
60
48
Trnava, Slovakia
Denafrips Gaia is at home!
Gaia has replaced my previous (pretty good for the money) Matrix Audio X-Spdif 2. Mainly use as USB to AES/EBU conversion from Aurender N100H to Simaudio Moon 380D DSD dac.
Just first impression (right out of the box, after just one hour of listening):
- impressive compared to X-Spfif 2
- sound is more airy, more analog like
- deeper, more holographic soundstage
- more realistic voices
Will update my findings after couple of days...
F2BDC343-7944-48FB-B8A8-C8E1FB4005B1.jpeg 709B7E2D-8AB8-4464-8492-589DE001A30F.jpeg 1DF45DE1-F2E4-47AA-B6BB-F1B70A986BBF.jpeg
Abyss Man
224
168
50
Hi Guys,
Any update with the HDMI cables? Much appreciated.
Blake
260
345
170
Hi Guys,
Hi Raj,
It seems my HDMI cable comparison is now further delayed.
We had a big wind storm here (110+ mph winds), which knocked over trees, which knocked over power lines, which took out power to my house for a few days. I hadn't been paying close attention (I have been working in my home office as my firm's offices are closed for COVID, and I have been listening to my new headphone rig while I work and therefore haven't been listening to my main speaker rig for a few weeks) so I am not sure if it was from the power situation but I went to listen to my main speaker system and noticed my Gaia wasn't powered on, and it now won't power up.
It wasn't a power surge, it was just a power outage, and even if it was a surge, I am double protected with a Blue Circle Yalu Balula and my PS Audio DS Power Plant 12, and all of my other audio gear is working fine and the Yalu Balula did not blow so that confirms it wasn't a surge situation.
I was thinking it was just a fuse replacement scenario. However, the Gaia owner's manual says there are no fuses or user serviceable parts in the Gaia. When I plug in the Gaia, I can hear some relay switching, but no LED's on the Gaia light up and the Gaia is not sending any signal to my Terminator Plus.
I ordered an Iris for my headphone rig, but it has not yet shipped. So, until I get the Gaia working, or the Iris arrives, my HDMI experiment is on hold :(
Reactions: Abyss Man
Abyss Man
224
168
50
Hi Raj,
We had a big wind storm here, which knocked over trees, which knocked over power lines, which took out power to my house for a few days. I hadn't been paying close attention (I have been working in my home office as my firm's offices are closed for COVID, and I have been listening to my new headphone rig while I work and therefore haven't been listening to my main speaker rig for a few weeks) so I am not sure if it was from the power situation but I went to listen to my main speaker system and noticed my Gaia wasn't powered on, and it now won't power up.
It wasn't a power surge, it was just a power outage, and even if it was a surge, I am double protected with a Blue Circle Yalu Balula and my PS Audio DS Power Plant 12, and all of my other audio gear is working fine and the Yalu Balula did blow so that confirms it wasn't a surge situation.
Hi Blake,
Oh man, I am so sorry to hear of the mishap and hope family and you are ok. No worries sir with the comparison its not a biggie. As for the Gaia, if after power cycling its still doesn't start up I pretty sure the relays have gone. It happened to me once with my Termy when I initially got it many moons ago. The relays were changed out I think. I would usggest getting in touch with Alvin, I'm sure the board can be replaced by you since they use a modular design.
Stay safe sir.
Blake
260
345
170
Hi Blake,
Stay safe sir.
Yeah, I am so ready for 2020 to be over (COVID, we also had an earthquake, then the windstorm... probably swarms of locusts and zombies invading next, because why not?).
You are probably right about the relays. I haven't contacted Alvin yet, but will do so. I am not worried about it as Alvin's customer service is the best in the business! He and I will get this sorted out, but now that I can't listen to my speaker setup, I really miss it.
I have been having some fun with my new headphone amp though, rolling in different NOS tubes. Can't wait for the Iris to arrive to inject even more clarity and holography.
Reactions: Koso and Abyss Man
Abyss Man
224
168
50
Cool, I have a heavily modified Little Dot Tube amp as well but its just picking up dust now. Its got Mundorf silver gold caps with upgraded wires as well. It sounds very good for the money. Damn, I think I might just bring it out again, but my SPEC is such a brilliant amp. Try running some Russian tubes, you will be surprised, especially the 6SN/L7 versions. Have fun Blake.
Reactions: Blake
Blake
260
345
170
Sorry Denafrips folks, this is a detour... please ignore.
Its got Russians in it now as they are the only source of of the 6C33C power triode tubes (only a couple Russian factories produced them), but the driver tube I have been using is an awesome RCA 5691 red base. But I just snagged some super rare West German military versions of the Mullard ECC35 to swap in for the 5691. These are all 6SL7 variants.
Blake
260
345
170
Your SPEC amp and Abyss are operating at the highest levels for sure TOTL stuff!
Koso
12
18
60
48
Trnava, Slovakia
Hi Blake,
I am very sorry to read about such issues. Please, let us know, when you will have any info from Alvin about repair process. If it was really problem of relays... As a fresh owner of Gaia I am little bit disturbed by such a flaw. And I am afraid, there is only a little chance of "module swap", because Gaia is single board design...
Abyss Man
224
168
50
Thank you the compliments Blake, u are very right, the SPEC and Abyss are a brilliant pair. It also pairs well with WA33 and Cayin H300.
Abyss Man
224
168
50
Hi Blake,
Nothing to worry Koso, with Alvin you are in safe hands, very safe hands even if u are from Timbuktu.
Reactions: Blake
HifiHandyman
3
11
3
51
Hi everyone, this is my first post. I recently (2 months ago) received my new Denafrips Venus II in silver. I had been using a BlueSound Vault 2i with its own internal DAC, or the DAC built into my surround processor for some time, but now I have taken the plunge to two channels only! So, most of the surround components are down in the basement collecting dust while I’m on a quest for two channel excellence. The Vault was replaced by the SMS-200 and the Venus II. At the change, my system took on a smoother and more detailed sound by quite a bit. Now, I’m almost 100% on board with adding the Gaia to my system, so I’ve been reading everything I can about it. I know several of you have added the Gaia with seemingly great results. I have all the usual questions, like “how on Earth could the Gaia help me?”, but so far the choices made by me have been pretty sweet. My system was teetering in “bright”, but the Venus II really made a difference. I am happy to be here and learn as much as I can. Thanks.
Koso
12
18
60
48
Trnava, Slovakia
Hi Hifihandyman,
Congrats to Venus 2!
Now, straight for your question “how on Earth could the Gaia help me?”
Well, in my opinion Gaia actually could help you. Your system is pretty good candidate for adding Gaia.
In general, I suppose, Gaia is not only great as DDC, but especially great in rising the sound quality of almost any digital source. The worse streamer or network player is used as source, the best result you can expect. In my opinion, the following ratio applies for digital source range vs sound quality improvement by Gaia or any other good DDC:
A: streaming straight from PC - BEST
B: dedicated streamer basic quality - GREAT
C: dedicated streamer medium quality - GOOD
D: high-end dedicated streamer - SMALL (if any)
Your SOtM sMS 200 lies somewhere between B and C range, so you will benefit from adding Gaia to your system. My streamer Aurender N100H is in my opinion better than sMS 200 (say C range), but still benefits from Gaia.
Let me think out loud for a while. Why are there so many models of streamers/ network players from the same manufacturer? In many cases the same functionality, similar design, same enclosure, same display, same control app. But the price of higher model is several times higher. I had compared N100H vs N10 once, and N10 is noticeably better. But why? What is different? There must be some difference, right? And there is. Better power supply, better filtering, better clocking (femto or higher), galvanic separation... Resulting in quieter and jitter free signal. The problem is that Aurender or Auralic or Melco or any other high-end company charges horrendous sums of such an upgrade (for example, my Aurender N100H is 2800 EUR, but one step higher model N10 is 8500 EUR).
And here comes Denafrips Gaia, which does exactly the same task (extremely precise clocking, quieter and jitter free output signal), but for fraction of the cost of high-end model of streamer.
So that's why I think Gaia could help you. It won't make a day to night difference, but it will be improvement. In your case (having Venus 2) you can benefit from i2s connection as well.
Koso
12
18
60
48
Trnava, Slovakia
GAIA REVIEW UPDATE:
I’ve promised that I will report my findings after Gaia settles a little bit in my system.
I am only at one third of burn in time period (roughly 300 hours is recommended by Denafrips), but I just can’t resist to share that sound quality of GAIA is still improving. As I wrote before, initial impression was very good, but just after a week of continual using I am really impressed.
It is almost unbelievable how big improvement can this DDC bring to already decent digital setup (Aurender N100H streamer + Simaudio Moon 380D dsd DAC). What I wrote before is still truth, but somehow multiplied and even more refined.
Sound is even more relaxed, soundstage and space around instruments has even more natural feel. The effect of “disappearance” of speakers is even closer to ideal (...to achieve this in my listening space, smaller square shape room, is very challenging).
EVERYTHING is more realistic! Voices and acoustic instruments are just THERE.
Great job Denafrips!!
Blake
260
345
170
Thanks for the report @Koso!
Reactions: Abyss Man and Koso
HifiHandyman
3
11
3
51
So, I did it. I took the plunge and ordered my new Gaia in silver. I’m super excited to get it into my system and see for myself how it performs in my system. I have an Audioquest “Coffee” HDMI cable on hand to make the I2s connection to the Venus II, so that should work for now. I have been trying to decide between the Tubulus cable or some other new Audioquest cables that are called 48 and look pretty sweet. Almost everything I have is AQ, so I’m tempted to keep it “in the family“. The next thing on my upgrade list is the fancy SOtM network switch and maybe I’ll pull the trigger on that too. Has anyone added the Gaia to the SOtM SMS-200? As always, any input, ideas, or opinions are always welcome by me.
