Ianus Essentia, TriodeFet amplifiers are out
flyer
423
179
1,160
Belgium
One pair coming my way next days :D.
Will be available for demonstrations as of December 19 in Belgium and the Netherlands!
We can arrange a demo at the dealer Alpha High End in Belgium or at my demo room with horn speakers near Brussels or in your system, whatever suits you best!
To remind: the Essentia is a single stage (!) triodefet amplifier with two small tubes per channel. It is not to be called a hybrid amplifier because the triode mounted tubes are in parallel to the output stage. The proprietary developed triodefets supply current to the triode signal and operate only in pure Class A without switching and have a power rating of 40 Watts.
Such class A power rating is substantially more than the big majority of fet-amplifier that are labelled as class A amplifier, as big majority of them only operate to a smaller portion of their total current rating in pure class A.
As with every Aries Cerat product, the reserve in current supply through its supercapacitors is so terrific, no switching may ever be missed! Finally, another upside is its stability down to 1 ohm, offering a true triode sound solution for even low impedance (dipping) speakers.
Worldcat
142
How do these sound?
flyer
423
179
1,160
Belgium
How do these sound?
How they sound? OK, i am sure your realise any answer will have a subjective touch to it but let me give it a try.
My own reference system (not picture above) comprises of the Aries Cerat Symphonia horns and a full AC suit of electronics. My reference amplifiers are the Concero Signature which pricewise come closest to the Essentia. So description below is what struck me between both amplifiers that are a quite different breed indeed.
Which difference finds it origin where is a whole separate debate of course because not only is the Ianus Essentia less powerful but it also features a lot more gain than the Conceros, they feature the proprietary triodefets and are single stage and single ended.
Transparency: i liked to think the Concero were already very open but the Essentia takes it a few notches higher! The amount of detail you can hear is stunning. They amount to an experience that doesn't bring the performers to your place but rather transport you to the recording venue. This is because also acoustic details of the recording venue for example are so well laid bare! Not just in the high frequency but also in midrange and low frequency reverb making for a totally immersive experience.
Speed: yes, Essentia's triodefets do seem to be 'faster' than the Conceros. In fact, only when listening to the Essentia i am reminded that the Concero are tube amplifiers.
Voices: i prefer the graininess of my Conceros still but that is because i am used to that probably. With the Essentia, in different environments with other people present, everyone thinks the voices and instruments are particularly well reproduced, without strain, causing no fatigue whatsoever.
Staging: the Essentia are a looking glass for the gear put in front and behind it, if that gear allows for a very wide - yet realistic - and layered depth, then the Essentia will bring that to the front in very convincing way.
Ultimately, the Essentia are about at the same level as the Concero Signature but with a clearly different touch. Lovers of transistors might think of the Essentia as the wholy grail as it offers the speed and heft of the best transistors in combination with the harmonic and musicality offered by triodes. Lovers that are enamoured with tube sound will embrace the Concero Signature as the latter offers that extra bit of graininess and majestic behaviour yet presenting it such like only a state-of-the-art tube amplifier can.
PS: listened this afternoon to the Essentia with the Marten Parker quintet, it was "magical" (not my words!)
Reactions: Marcus and RdW
Worldcat
142
How about compared to the Concert 25's? Thanks for your take.
flyer
423
179
1,160
Belgium
Hmmm, the Concero 25, me like a lot sir!
But it pains me to say that the Essentia probably betters it in about all respects. Of course if you are particularly fond of the 845 tube (sound) then you might skip the Essentia.
But beware of the different gain and different power rating. Depending on speakers you might not need the extra power really.
Thing is, being a single stage design, the Essentia offers a very OTL-like transparency that you will not find with the Concero series. And the Essentia only has two small tubes per channel that have a projected lifespan of >8000 hours!
Worldcat
142
Do these have enough power to run 90db speakers?
CKKeung
3,058
3,190
1,410
Hong Kong
Reactions: flyer
Believe High Fidelity
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
Legolas
1,042
387
455
France
The Aries Cerat Essentia with the Marten Parker Quintet at our dealer, Alpha High End in Brussels
Soon ordering the Essentia for our demos in Spain. This is a breakthrough product, and gives you big bottle Triode timbre and realism, everything I love about the magic of a SET, with Class A solid state bass control and bass details. A killer of an amp! So realism in spades with no compromises. Can't wait....
Thieliste
815
296
360
53
Is it possible to use an Impera ll Ref to drive Essentia monos ? and is it a good match ?
As i undestand there will be a new 2 chassis linestage for the Essentia but much more expensive than the Impera.
morricab
9,483
5,042
1,228
Switzerland
Yes, Impera works just fine with Essentias.
Reactions: Thieliste
flyer
423
179
1,160
Belgium
The reason for the new preamp 'Ageto' launch, is primarily is the lower gain that preamp has.by default as the Essentia has a lot more gain (between 20 and 24 dB depending on tubes) than the big tube models from Aries Cerat. So, there is less gain expected to come from the preamp.
The Ageto is effectively more expensive than the Impera II Reference but you will not be disappointed with the sound gain!!
By the way, you can also order a low gain version of the Incito S or the Impera II Reference, so you still have the perfect match.
At a dealer in Brussels, we match the low gain version of the Incito S with the Essentia to great success.
Thieliste
815
296
360
53
Well i would love to get the Ageto for the Essentia but the price is out of reach for most of us:(
My only option would be the Impera ll Ref low gain version as you suggested.
Otherwise there is the Aperio integrated but i would prefer to go separates in the future as i already own an integrated.
Hopefully the Munich show will take place this year so we can listen to Stavros's new gear.
Verdier
131
138
148
I run Ianus with Impera Sig. (the same as Impera Ref. in terms of amplification). The Ianus is turned down a few db using its TVC (my speakers are 93db/1Watt) and it works wonderfully.
Previously I had the Impera Ref. and it played wonderfully with it too (see my posts). With an Impera with low gain it will sound a bit better!
Your search has been going on for a few years though. One could get the impression that you spend most of your time brooding. You can do that. But listening to music with AC is much more fun than brooding. ;)
Thieliste
815
296
360
53
In case you didn't follow my journey i do have a system up and running and very happy about it.
Just asking questions about the new AC gear nothing else.
Legolas
1,042
387
455
France
It don't bother me you asking. This hobby is a journey. If you are still moving forward, you are not there yet? Maybe? The Essentia is my end game power amp, no question. Now I just need to get folk here to hear it!
Legolas
1,042
387
455
France
The Essentia is probably the biggest 'break out' Aries Cerat amp yet. By that I mean it is super flexible, and can fit with so many system configurations. I think it will be a best seller, such high end performance.
Thieliste
815
296
360
53
Hey Julian how are you doing ?
What preamp do you use with your Essentias and how is that pairing ?
