dminches
3,437
2,815
1,410
Was it established that one cannot a Qobuz album to favorites from within TAS? If that isn’t true can someone explain how it is done.
heebrog
131
51
135
Perth, WA
Select at album and add it to your queue.
I have chosen Beatles Abbey Road in this example.
Click the 3 vertical dots at the right of the track to open the drop down menu.
Select "More"
A drop down list will appear on the left pane in TAS.
Select "On Qobuz" at the bottom of the list.
A new drop down list will appear.
Select "Manage Favourites" at the top of the list.
Select the middle one.
Screen Shot 2021-04-25 at 12.56.30 pm.png Screen Shot 2021-04-25 at 12.56.41 pm.png Screen Shot 2021-04-25 at 12.56.55 pm.png
dminches
3,437
2,815
1,410
Select "More"
Thanks for this.
That worked and added the album to my Qobuz favorites in TAS but it doesn't seem to add it to Qobuz's database. When I go into Roon that album doesn't appear. Is that your experience as well (assuming you have Roon)?
What I have been doing is going into Roon and adding it there and then rescanning my TAS library. Doing that results in the album appearing everywhere.
marty
4,195
2,520
United States
Can you tell me exactly what to do to "rescan the TAS library" so all my Qobuz favorites appear there automatically from Roon. ?
dminches
3,437
2,815
1,410
Server settings / rescan
442FDF1E-C63B-476F-93BF-B0322003FB5C.png 50289DFC-2537-4B73-900E-26D1E7E2CA24.png
Reactions: Taiko Audio
heebrog
131
51
135
Perth, WA
Thanks for this.
I haven't used Roon since TAS but this method adds the album to Qobuz in the app which I use for search sometimes both on my laptop and iPhone.
dminches
3,437
2,815
1,410
It eventually showed up both in Roon and Qobuz.
Thanks for the tip.
Reactions: heebrog
EuroDriver
926
2,479
450
Monaco
I have it connected. It works well, playing music using our USB card right now. I will leave it running over the weekend and have a serious listen next week.
I have had the upgraded Reclocker playing for several hours now.
The system is D1-12 > Stern > Heisenberg > Magico A5
I can't give a before and after upgrade comparison as I have not the D1-12 for a long time. However in terms of absolute sound quality my comments are
- superb tonal beauty
- abundance of fine detail and nuance
- tracks sound like a live performance and not a recording
Definitely a top drawer DAC, now blooming even more with TAS, Taiko 5.0 Driver and Taiko USB card
My feeling is that in this low noise playing field, the audible and perceivable Sonic Delta between DAC’s has increased
Skanda
246
292
133
just wanted to follow up on my earlier question about playlist length. i have a tidal playlist that is 1100 tracks long roughly and i keep adding to it. via TAS only 537 items are displaying. i google'd around and there seems to be a squeezebox setting to manually set a max playlist size. i logged into squeezebox but didn't see that in settings. any ideas?
cat6man
898
1,002
1,185
west of NYC, east of SF
settings > advanced > performance
see link below
dminches
3,437
2,815
1,410
Reactions: Skanda
cat6man
898
1,002
1,185
Can you show a screenshot? I don’t see “advanced” under “settings”.
Do you mean “server settings” / “performance” / Maximum playlist length?
i haven't done it myself..............results from a search on squeezeplayer forum
cat6man
898
1,002
1,185
I thought playlist length is now predetermined as to how much can be cached for the batch player. I thought it was 20-30 minutes or am I wrong
batch mode limit is 20+ tracks total.
there is no limit i've seen in single track mode for the number of tracks in the playlist
Skanda
246
292
133
i think thats the play queue. the playlist itself is from tidal
thanks for the link @cat6man. this was the thread i found googling around as well but also can't find that option in my settings. these are the only options i have (account settings is just email and name stuff):
heebrog
131
51
135
Perth, WA
@Skanda.
Is this what you mean?
See bottom of screenshot.
Mine is set to 500.
If I add new tracks, the ones at the start of the queue get deleted automatically.
I have not tried but a setting of 0 should give an unlimited playlist length.
G
Skanda
246
292
133
Thanks @heebrog, this is exactly what I'm looking for but i can't find it in the mysqueezebox portal. This is what I'm seeing (note that account settings has no option):
