Reference Analog
Fleetwood Sound Owners Group
Will do George.Let me know when you get the No 25's in the store ... will try to get up there to take a listen.
Thanks
George
Thanks
George
I will for sure!If you hear them, please do post your impressions if you can. Most intrigued...
Thank you, George, for this very interesting and detailed report! I have never actually even heard REL No. 25s (I have heard several times only my friend's 212/SEs -- which are wonderful). But I have always harbored the suspicion that the No. 25 must be fantastic!
Are you using the speaker level input or the line level input on the RELs?
I appreciate that this is probably a premature question, but does your experience so far incline you to imagine what two No. 25s stacked on each side, or three stacked on each side, might sound like?
Thanks! I will hazard a guess that part of the disappearing act of the No25's is the fact that they have properly sized the enclosure for the driver. The enclosure is actually quite a bit larger for 1-15" driver than the enclosure Martin Logan uses for 2-12" drivers. Only time will tell if I can resist the pull of adding another set or two of these huge subs!George,
Congrats! That is really big news...very interesting comparison as well. The arithmetic suggests that 212 has slightly more cone surface area than the REL25 but not much, and I have not checked excursion. So interesting that you feel it has more outright output...but I cannot imagine the 25 does not have plenty of output.
And of course, the inevitable question is something Ron beat me to...which is of course stacked...ie, another pair of 25s!!! Ha!
Fantastic! Look forward to reading all about the setup!Our No25’s arrived at Reference Analog. I will let you guys know how they pair up with the Rockports
Thanks! Look forward to reading what your dealer says about the 2nd set!Thanks! I will hazard a guess that part of the disappearing act of the No25's is the fact that they have properly sized the enclosure for the driver. The enclosure is actually quite a bit larger for 1-15" driver than the enclosure Martin Logan uses for 2-12" drivers. Only time will tell if I can resist the pull of adding another set or two of these huge subs!
George
I think that REL has one of the best manuals for setting up a subwoofer. It's very thorough, yet simple and understandable for everybody.I just got these two G1 Mk2 and I set them up yesterday with the help of Rel and we spent a while positioning each sub omn its own and then after that was done we did some small adjustments to make them seamless. I am not really a sub fan but these woofers work really well and sound is excellent. I am thinking of stacking more but I will give it some time to fully settle in and I have a few little tweeks I have yet to do.
Impressive indeed. Need to take a listen to that. It's so hard to get it right. So it's kind of a BMR?That's not a tweeter; that's the amazing bending wave nearly full-range driver!
BMR is a Balanced Mode Radiator, it's those flat diaphragm drivers that can play very wide in terms of frequency. That was my guessI do not know what "BMR" means.
Very interesting stuff. Is there anything more to read on it?Music travels across the Bending Wave driver like on the sound board of a musical instrument. It is not a push pull driver, not a dipole, not a bipole.
It is full range from 160hz to over 30000 hz.
