Belt drive can be pretty nice. But Technics solved all the control theory problems with servo control decades ago; after all they had a pretty big R&D budget being owned by Panasonic, and control theory isn't mysterious anywhere but in audio Its no longer an issue. Take it from someone who has been making belt drive turntables for over 20 years now.Think you have to decide if you want belt or DD before recommendations make sense
Just getting ideas at this point. Will be pairing with Ref Phono 3SE and Lyra Etna Lambda cartridge.
Thanks in advance...
read your own magazines. they have plenty to say on the subject.
i imagine something might be worked out.
just kidding....could not help myself.
Thank you.Lol .
So the CEO of 2 leading Hifi magazines comes to WBF to ask for advice , what about asking your reviewers ( )
By the way you have a nice system
I have been impressed by the Viella in the past...The AMG Viella is squarely in your price range, and has been mentioned as a great value in several reviews. You can upgrade the tonearm to the 12JT (“turbo”) version. I have been using one now for a half-dozen years — for a long while with a Benz LPS cartridge. I upgraded my cartridge to an Etsuro Gold and the table doesn’t under-represent even with a cartridge as expensive as the table. Easy to setup, low fuss table that gives a sizable dose of what a good table can deliver.
Either works.Think you have to decide if you want belt or DD before recommendations make sense
Prefer new.Are you considering a current new turntable or getting an used one?
makes sense Lee. here you go.Hi Mike! Hope you are doing well...I just figured I would listen to both reviewers and folks here...I have already spoken to several reviewers. More opinions are better.
