Yes and no. You have to listen to adjust the width but Jim's done thousands of rooms and Wilsons usually sound their best at 82-84% according to him.
Sorry, 82%-84% of what?
that's what I said...I thoughtAs far as I read in the XLF manual it just says " The listening position should ideally be no more than 1.1 to 1.25 times the distance between the tweeters on each speaker."
What is the ratio you currently have in your system?
Out of interest I might add that the best Wilson set up I ever heard was a few years ago at Alma Music in San Diego when I visited Alex to hear the Alexia 2 . It ws set up in their large listening room and when I sat down. the first thing I noticed was that I was sitting in the sweet spot but inside the triangle. I questioned Alex about his set up and he stated that he and Fabio did the set up entirely by moving the speakers 1/4" at a time until they both agreed on where they sounded best. Interestingly their ratio was also 0.8. Shortly thereafter ddk visited and set up my van den hut cartridge. After we were done we sat down to listen. David slowly moved around my room and then sat himself down and said, "this is the the spot where your room is totally removed from the equation." When I measured the ratio was exactly 0.88 Presently where I sit , the ratio varies between 0.88-1.0. My upper modules were changed to suit a provided algorithm in the Wilson manual and I have zero issues with sound stage or size of singers and instruments etc.that's what I said...I thought
As stated my set up now defies all Wilson algorithms . My ratio is between 0.88 -0.90 so I am just inside the triangle
+1 on ceiling treatments especially since I have 30° angled eaves from midline apex. Has been crucial to approaching an endgame sound.Very nice, Lee. In my room, ceiling treatment has been absolutely essential, as I describe on this page:
My monitor/subwoofer system, page 9
My room though is only 8.5 ft high. Your room appears higher from the image, so the ceiling may play a lesser factor. My ceiling also has nasty acoustic properties, as I outline in my report.
As for the effect of small lateral moves of the speakers in my system, see the currently last page 35 of my thread. These latest moves appear to correlate with your experience.
The original post mixes Jim Smith and Wilson Audio advice, it is not clear to me. Probably it is semantics, can you explain what is exactly the "center mark" and how was it established? Thanks!Explained in the original post.
Jim uses a Leica laser device to measure the room and the center mark is simply half the width. Then in the back of the room he attaches another laser that projects the red laser line across the room for positioning the listening chair then a tripod with a vertical card between the speakers. Once you have that center card, you have an ultra precise way to measure speaker distance from the center of the room. He also places a piece of masking tape on the wall and traces a line based on the projected red laser line. That is useful for positioning the GIK panels.The original post mixes Jim Smith and Wilson Audio advice, it is not clear to me. Probably it is semantics, can you explain what is exactly the "center mark" and how was it established? Thanks!
Nice to know. Maybe you could publish an article about his listening room in TAS!In the X over Y ratio, Jim’s vast experience in setting up Wilson speakers is that 82-84% is the ideal range.
But the biggest tool in his three bags of setup gear is his ears. He has 95+ tracks of go-to music which allows him to test all sorts of things from soundstage depth and width to dynamics to bass response, all subjectively.
It is a really valuable, programmatic way to optimize the room. Jim is just twenty minutes away from me and he has a detached garage that is a purpose-built listening room. It is simply breathtaking how good his 16/44 tracks sound in that space. The bass is among the best I have heard.
Thank you. Jim measured from his right ear to the right speaker. Earlier on in the setup, he measured the distance from left ear to left speaker.Lee, congratulations on your improved sound through the room play. Jim came to provide those services to me a number of years back and he made a tremendous improvement to my enjoyment of the music.
Perhaps you can clarify something for me. I recall the XY ratio. If I recall correctly, the X distance is tweeter center to tweeter center. But I can’t remember if the Y dimension is ear to tweeter or if it is center of head to a spot exactly centered between the two tweeters. Thank you.
We are strongly considering that. It is an impressive system and room but surprisingly affordable.Nice to know. Maybe you could publish an article about his listening room in TAS!
Generally speaking we toed in until you could not see the speaker sides from the listening chair.One other question. Where did you end up with toe-in? Enjoying this thread! Thanks for starting it.
Tom
OMG...that is my audio nightmare! I have to reprogram the TV remote every other Netflix session. Happy Listening...A little afraid she's going to ask me how to turn it on.
