Aurora speaker...coming up
matthias
1,252
552
213
Germany
Hello gents
Video from final auditions of the Aurora.Soon to hit the shows...
Cheers
Stavros
What is the position of Aurora in the AC speaker hierarchy in relation to Symphonia?
Thanks
Aries Cerat
359
607
333
Hello Matthias
The Aurora is an unofficial replacement for Symphonia,which though not obsolete, it will be made in VERY limited pieces.
That said ,the Aurora project was not initially intented to replace Symphonia.It was a personal side project, somewhat proof-of-concept kind of design/prototype. Somewhere along the way,the project really took off and many design aspects of the speaker are quite new in our line. The top version of the new speaker is IMVHO superior.
Cheers
Audiophile Bill
4,293
4,093
675
What are the 4 x 12” woofers - look like Acoustic Elegance TD12?
Alrainbow
3,253
1,429
450
I was at axpona and heard this setup a few times . I advised many to go to that room . Some heavy hitters on here too . All the reps of this room were very kind and informative . The sound was great such a cohisive sound , i just wish it was a bigger room for these . The above first post a larger system made me have to hear these . How this large setup could have such a massive sound and not have a hint of sharpness or uneven sound alone is amazing to me . I hope other more known and skilled attendees post about this system . To me this is a room that once heard put me at such a high level it made it hard to hear most other rooms .
matthias
1,252
552
213
Germany
Hello Stavros,
please can you describe with a few words the different versions of Aurora.
Is there also a fully passive version?
Thanks again.
Argonaut
2,422
1,655
530
N/A
Hopefully the A 4.2, E213 room in Munich will prove a little more commodious and allow the Aurora’s to breath and show more of what these phenomenal transducers are capable of.
matthias
1,252
552
213
Germany
Reactions: Argonaut
Aries Cerat
359
607
333
Hello Stavros,
Thanks again.
Hello
The options are both aesthetics,and performanced oriented.
Let's skip the former...
1.One main option, is the use of a much higher caliber compression driver for the midrange, and a different length midhorn. The specific optional driver is also used in our Contendo speaker, and can be loaded (using of course the proper horn) down to 80Hz! In the Aurora of course it is crossed at 280Hz , when using this driver and horn.
2.The Bluetooth tuning module. This tech was developed for the Contendo crossover, but has taken it's role as (optional) module that controls several parameters of the speaker using our phone application. This is not digital domain module,no A to D to A or dsp, , but fully analog line and speaker-level filters, that their parameters are modified on the fly using our
app-controlled switches.
One of the reasons why the Aurora could the play the way it could in a 4x5 room in Axpona, and at same time the same speaker can fill our 450sqm space, is this capability, of tuning and "taming" the speaker to suit the space it is loading.
3.The built-in amplifier, can be upgraded, or bypassed while using an external amplifier ,ex. using any of our other amplifiers in our lineup.Anything from a humble Concero to a Geminae can be used as the amplifier of the active section. As you can imagine this option opens up a lot of possibilities. No need for cross or wiring modification, cross box is ready to go, and any other amp can be plug and play.
4. Umbilical wires,as you can imagine, this is small details compared to the other options, but still ...
The speaker can play fully passive without any internal mod on the cross. The active section is same sensitivity as the mid/treble section, so it can play passive. However you cannot exploit the use of the active filters and what these add to the result.
Cheers
Stavros
morricab
9,525
5,054
1,228
Switzerland
Will you be at the show?
Run-RMC
29
12
10
UK
Imaginative design, I like the idea of Bluetooth tuning. I"d like to hear these when time permits. What's the RRP for these horns?
Reactions: Renoguy
