Which cables do you use with CH Precision products?
I actually have the AU24SX I/C and S/C on a second system and like it a lot, organic and very evenly balanced across the board. Strange you found the Frontrow w/ less bass and treble spike as most user reviews I have seen suggests it is slightly warmer and more meaty compared to the SX. What model Shunyata cables did you try?
Keep in mind the AU24SX SE is different from the non-SE version.
I tried Shunyata's top of the line speaker cables (Sigma V2) but don't remember which ICs but to be fair they weren't Sigma.
When I bought the AU24 SX cables I recall it was the TOTL of Audience at the time prior release of Frontrow, w/ the SE next model below it. The local Shunyata distributor won’t stock Shunyata signal cables so only way for me to try is buy. I have read superlative reviews of both their Sigma and Alpha I/C and S/C specially the V2 you tried.
Sorry I confused the two. SX is what I have and indeed is the version just before FrontRow.
If you ever get hold of the Sablon I/C or S/C would love to hear your take how it compares with the AU24SX. From Sablon reviews it sounds like it possesses the same attributes of the Audience that I value but possibly taken to a higher level.
I would love to try them. I have a Sablon ethernet cable that I think is great.
Reactions: Sablon Audio
I am new to CH P, having recently acquired L1, X1, A1.5 - hopefully adding P1 soon (just to think about those differing RIAA curves for my old classical lps …).
A complete loom of NBS monitor 1 cables had served my JRDG Coherence II and model 8 very well.
I wonder how these work with CH P.
If and when replacing these NBS, where to begin?
Sablon’s prince ac (feeding the Taiko Extreme), ethernet and usb cable made me a fan of these.
Having read this thread and descriptions of Sablon paired with CH P, I do lean towards Sablon.
Where to begin?
Which NBS monitor 1, ac, xlr, speaker cable, being replaced with (most probably) Sablon would have most effect?
Thx for your advice!
I use MasterBuilt Ultra on my CH Von Schweikert display system and Jorma Statement on my CH Marten display system. Argento I've heard many times with CH and find them excellent as well.
I am a MasterBuilt distributor, now a Jorma dealer and have no connections whatsoever with Argento.
Reactions: engadin
Will the Argento speaker binding posts allow two sets of speker cables for biwiring?
Well, I did like very much what Sablon usb, Sablon ethernet and Sablon prince power cable did for my system.
So I had ordered quite some time ago
- Sablon XLR from t&a 3100 DAC to CH P L1
- Sablon XLR from L1 to CH P A1.5
- another Sablon prince power cord for A1.5
- Sablon speaker cables
There was some delay due to availability of Bocchino connectors, but …
to say I am pleased with the results would be a gross understatement.
I do love what these cables do.
PS: the Bocchino iec plug was very wobbly in the CH P A1.5 inlet.
A Tripplite iec sleeve would not slip over the mighty Bocch.
Some warmth on the Tripplite did help, so keep it a few minutes in hot water and then proceed.
You will see the yellow sleeve in the pic. No more wobbling.
Highly recommended, Tripplite iec sleeves and all things Sablon!
