Abbas dac 2.1 se
djsina2
1,126
964
213
Do you know if Abbas has matched the model to your new one? You wrote that the replacement DAC is modified and should sound better.
I don’t know. Abbas seems to not have a “standard”. Something today is different tomorrow. I didn’t notice any difference in sound between the two. It may be a case where you need an A/B switch flipping back and forth to notice. The innards look very similar but not exact.
trinley
43
45
125
Duesseldorf
Thank you!
Are you also using the 6SN7 soviet tubes with your new 2.4 SE?
Does the DAC get very warm when the DAC with top is used?
djsina2
1,126
964
213
Thank you!
I’m using the RCA red base. I would say it gets warm but not hot.
charles1dad
450
571
330
69
Michigan, USA.
I mostly listen to vinyl but I played the Abbas yesterday for the first time in a while. Sounded great feeding it from CEC TL1.
“Sounded great “. Probably not close to being burned-in fully with infrequent usage.
Charles
trinley
43
45
125
Duesseldorf
Are also not so cheap :D
I still have to read a little about the different variants of 6SN7. The most expensive are GEC METAL BASE and BRIMAR "Black Beauty" cost up to £ 1000 per piece.
Reactions: Artnet
charles1dad
450
571
330
69
Michigan, USA.
I believe Abbas has said it doesn’t need burn.
Okay. Abbas told me recently my 3.2SE DAC requires 200 hours to be thoroughly burned-in. I just assumed (Maybe erroneously) there wouldn’t be much different with the 2.4SE.
Charles
charles1dad
450
571
330
69
Michigan, USA.
@jespera
You have 3 Abbas DACs. What is your burn-in experience with them?
Charles
jespera
494
539
200
London
@jespera
Charles
Id say 100h+. But it may be valve dependent. I find that all nos valves need a bit of time before they peak. Some more than others.
With the right 6sn7 that 2.4se will sound very nice. Too bad the jacmusic sylvania 7n7 (15 eur) with adapters will only fit with the lid off.
charles1dad
450
571
330
69
Michigan, USA.
Variance of tubes as a factor makes sense. Abbas utilizes Blackgate capacitors, and many believe they require a substantial burn-in period to sound their best. Then there's lots of wire in the multiple transformers as another possible factor.
Charles
Reactions: trinley and jespera
trinley
43
45
125
Duesseldorf
I have the following tubes to chose:
6SN7GT Brimar UK NOS. Red logo. Clear glass 170 GBP
6SN7GT Brimar UK NOS. KB/FE version. Black glass. 400 GBP
6SN7GT / VT231 USA NOS, Kenrad 160 GBP.
6SN7GT USA VT231. NOS, Tung-Sol, L round anode 300 GBP
6SN7W Sylvania USA NOS. Metal base 180 GBP
6SN7GT Mullard, UK. NOS. 190 GBP
Does anyone have experience with these tubes on the 2.4 SE?
jespera
494
539
200
London
I have the following tubes to choose:
They all look like top shelf to me.
Melz 6sn7 is another option but it’s gotta be the right version.
Ask Abbas for advice.
djsina2
1,126
964
213
Yeah, Abbas told me RCA red base or the Melz. I use the red base because they are shorter.
Reactions: trinley
facten
968
1,027
140
Tennessee
@charles1dad - Did you receive your Abbas, and if so any initial impressions?
