A friend asked me to spec him a system for a $2k budget.
He has a drive with music files. He wants to stream spotify. He needs an amp and speakers that will shake the room.
Suggestions?
I am truly blown away by the sound quality of a Lindemann Limetree Network streamer/dac. My system has been analog only for 30+ years and after trying Lumin and both Cambridge all-in-ones, I took a flyer one more time on this Limetree. Lindemann has the pedigree to do streaming right and it shows. And the form factor is awesome too. I will add that your friend should plan on Qobuz or Tidal rather than Spotify. For me it made the difference from just using it to explore music to actually playing it for serious listening.
Amp and speakers -- lots of options, listen first if you can. Maybe powered speakers will be a good option for him.
