36 inch gas range advice needed
bmw041586
1
I'm looking for advice on a 36 inch gas range for my kitchen. I'm a novice cook so I don't need anything fancy (re: not looking to spend $5k+ on a range). I recently purchased a home and the previous owner took the stove so that is why I need to get such a large one. The NXR Entree 36 in. 5.5 cu. ft. Professional Style Gas Range with Convection Oven in Stainless Steel seems like it has good reviews but I can't find reviews for it anywhere else other than Home Depot. I've seen a few that are less expensive but they have electric ovens and from what I've read I think I want all gas.
Does anyone have experience with the NXR Entree or any other 36 gas ranges that are reasonably priced?
MtnHam
275
50
335
Nothern California Wine Country
I too was considering a 36" gas range until I discovered all 36" ranges are in the $4-6K price range. It seems none of the manufacturers of normal priced ranges make one; you are forced into the Mega$ brands- Viking, Wolf, etc.
RogerD
3,734
319
565
BiggestLittleCity
I would make sure that you have some clearence for fire safety on adjoining areas. Check how the total weight compares with other ranges. I like the porcelain finish below the six burners. I had a Thermador and was a engineering nightmare. This looks like it's well thought out and the price is almost too good. If you buy from Home Depot that might make me a buyer if I needed one...but I don't.
KeithR
5,174
2,861
1,898
Encino, CA
Blue Star is the best value out there with arguably the best burners. Wolf may be better, but 2x the price.
rugyboogie
127
1,600
Vancouver, BC
We just bought a Blue Star, build quality better than the Wolf.
Using an 58" AGA for our Island home. Never ever breaks down.
