Hello,
I have read that the precise amount of torque that is applied to the screws that fix the cartridge is very important, and that minute changes, as small as 0.01Nm, can make a diffence in the sound. One Linn dealer described his use of a Sturtevant Richmont CAL 36/4 adjustable torque wrench to precisely set the screws and find the best setting by ear.
http://forums.linn.co.uk/bb/showthread.php?tid=8068
Anybody here with experience in calibrating the torque of cartridge screws? What would be the best setting for a Lyra Atlas on a Schroder LT?
If this is indeed the case, maybe we could make a table listing the best torque for certain cartridge/tonearm combinations. I suppose it will also depend on the cartridge screw used, in case it is not the standard one provided by the manufacturer.
Cheers,
VPN
Cheers,
VPN
